.NET
How can dwg use in web page
4 REPLIES 4
chowcool
287 Views, 4 Replies
i want to let a dwg file browser in IE,
how can do it,?
i use .net api change a dwg file to jpg,so i can show it in IE,
but there is many question, change a dwg file to jpg file,
you should use plot dwg to jpg,but plot a jpg it very slowly,
use autocad itself plot just use 2 second,but i use .net api
plot.PlotToFile(),it use 30 second about,why?
4 REPLIES 4
in reply to: chowcool
publish/plot Dwg file to *.dwf file is the AutoDesk's solution of viewing
dwg data on the web. Although many choose PDF.
wrote in message news:5202160@discussion.autodesk.com...
how can do it,?
chowcool
publish/plot dwg file to *.dwf file , if i don't install activex ,
i can browser in client?
You need to install Acad Express Viewer to view *.dwf (stand-alone or inside
browser), just as you need Acrobat Reader for *.pdf.
wrote in message news:5202412@discussion.autodesk.com...
chowcool
it is not i want to see,
i can't install activex in every client,
is there any other way to see *.dwg file in IE?
”Boost
