.NET
.NET
Active Member
0 Kudos
Post 1 of 3
How AutoCAD Set folder in options during statup?
157 Views, 2 Replies
09-11-2013 11:33 AM
Hi my query is:
The list of folders for network drives or local will be part of configuration XML. User should just modify the XML and AutoCAD would set the folders in options during startup. The XML would contain data for different profiles
502 Kudos
Post 2 of 3
Re: How AutoCAD Set folder in options during statup?
09-11-2013 11:41 AM in reply to: imvivs
Very possible - its what we use.  There is some substantial work involved to get it to work right, so I would suggest planning everything out first.  Code is the end product, not the starting point.
Adopt. Adapt. Overcome. Or be overcome.
A good question will be halfway to a good answer.
Distinguished Mentor
80 Kudos
Post 3 of 3
09-11-2013 12:24 PM in reply to: dgorsman
I wish more 'standards' settings were stored externally in XML schema (able to be specified per-Profile), similar to the way Civil 3D targets one of multiple external pipes (more accurately parts) catalog, etc..
Another Civil 3D example would be when data referencing an Alignment... The referencing drawing's available styles control the display of the alignment, rather than the host drawing, as is the case when XREFing same.
Sorry for all of the Civil 3D references; it's what I work with mostly.
Cheers
"Potential has a shelf life." - Margaret Atwood
Autodesk Exchange Apps ~ Autoloader ~ AutoCAD Security
AutoCAD® 2014, and Civil 3D® 2014 Certified Professional ~ Autodesk® Authorized Developer
