.NET
norman.yuan
Message 11 of 12 (85 Views)
Re: How a DWG is opened
09-17-2013 06:53 AM in reply to: StormyC
If you only want to run some code once on each drawing, you can hook up DoucmentActivated or DocumentBecameCurrent event when your IExtesionApplication assenbly is loaded on AutoCAD startup. Then, I'd use Document.UserData to flag it. Something like:
void DocumentBecameCurrent (....)
    bool processd=false;
    try
        process=(bool)e.Document.UserData["MyDwgOpenProcess"];
    catch{}
    if (!processed)
        e.Document.UserData["MyDwgOpenProcess"]=true;
        e.Document.SendStringToExecute("MyCustomCommand "....)
Valued Contributor
StormyC
Message 12 of 12 (83 Views)
09-17-2013 07:15 AM in reply to: norman.yuan
Again many thanks for taking the time to reply.
I will try that out and post back, will not be for a while though...
