Hi everybody!
I'm currently struggling with highlighting BlockReferences. My required behaviour is that I want to highlight the entities of a block, but not the nested BlockReferences inside it.
Example: If I do
myOuterBR.Highlight(path, false)
the whole entity and also the BlockReferences inside will be highlighted. I then tried to go through the BlockTableRecord of the outer BlockReference and do an
myInnerBR.Unhighlight(subpath, false)
to each of them, without any effect.
The other way I could implement it is to highlight each non-BlockReference entity inside the outer block by its own, but I guess this will not be very performant on blocks with a lot of entities?
Do you have any hints on this matter?
Thanks and regards
Max
well, ok. I implemented the "highlight each inner entity but BlockReferences" solution that I already mentioned. Though it's too bad, there is no other way.
Regards
Max
