.NET
Valued Contributor
Ertqwa
Message 1 of 8 (430 Views)
Highlight part of polyline
430 Views, 7 Replies
07-30-2012 11:01 AM
Hello Forum,
is it possible to highlight a part of a polyline in someway?
Thank you.
Here is another way, see maybe it will working on your release
 using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.Geometry;
using Autodesk.AutoCAD.GraphicsInterface;
using Autodesk.AutoCAD.Colors;
//_____________________________________//
[CommandMethod("colseg")]
public void ColoredSegment()
Document doc = Application.DocumentManager.MdiActiveDocument;
Database db = doc.Database;
Editor ed = doc.Editor;
PromptEntityOptions peo = new PromptEntityOptions("\nSelect Segment of Polyline:");
peo.SetRejectMessage("\nMust be a Polyline!");
peo.AddAllowedClass(typeof(Autodesk.AutoCAD.DatabaseServices.Polyline), false);
PromptEntityResult per = ed.GetEntity(peo);
if (per.Status != PromptStatus.OK)
return;
Transaction tr = db.TransactionManager.StartTransaction();
Autodesk.AutoCAD.DatabaseServices.Polyline pl = new Autodesk.AutoCAD.DatabaseServices.Polyline();
IntegerCollection ic = new IntegerCollection();
using (tr)
Autodesk.AutoCAD.DatabaseServices.Polyline pline = tr.GetObject(per.ObjectId, OpenMode.ForRead) as Autodesk.AutoCAD.DatabaseServices.Polyline;
if (pline != null)
BlockTableRecord btr = (BlockTableRecord)tr.GetObject(pline.OwnerId, OpenMode.ForWrite);
double bulg = 0;
Point3d picked = pline.GetClosestPointTo((Point3d)per.PickedPoint, false);
double par = pline.GetParameterAtPoint(picked);
int m = (int)par;
Point2dCollection verts = new Point2dCollection(2);
SegmentType stype = pline.GetSegmentType(m);
if (stype == SegmentType.Arc)
CircularArc2d arc = pline.GetArcSegment2dAt(m);
bulg = pline.GetBulgeAt(m);
verts.Add(arc.StartPoint);
verts.Add(arc.EndPoint);
else if (stype == SegmentType.Line)
LineSegment2d ln = pline.GetLineSegment2dAt(m);
verts.Add(ln.StartPoint);
verts.Add(ln.EndPoint);
bulg = 0;
pl.AddVertexAt(0, verts[0], bulg, 0, 0);
pl.AddVertexAt(1, verts[1], 0, 0, 0);
pl.ColorIndex = 121;
ObjectIdCollection ids = new ObjectIdCollection();
btr.AppendEntity(pl);
tr.AddNewlyCreatedDBObject(pl, true);
verts = new Point2dCollection();
if (pl != null)
TransientManager tm = TransientManager.CurrentTransientManager;
tm.AddTransient(pl, TransientDrawingMode.Highlight, 128, ic);
if (pl != null)
pl.Erase();
pl.Dispose();// optional, might be removed
tr.Commit();
// pause for user input only
string key = ed.GetString("\nPress any key: ").StringResult;
TransientManager.CurrentTransientManager.EraseTransient(pline, ic);
~'J'~
Hallex
Message 2 of 8 (421 Views)
Re: Highlight part of polyline
07-30-2012 12:58 PM in reply to: Ertqwa
Try thsi code
        [CommandMethod("Segh")]
        public void SegmentHighLight()
            Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
            PromptEntityOptions peo = new PromptEntityOptions("\nSelect the segment to copy: ");
            peo.SetRejectMessage("\nYou have to select polyline only!");
            peo.AllowNone = false;
            peo.AllowObjectOnLockedLayer = false;
            peo.AddAllowedClass(typeof(Polyline), true);
            if (per.Status != PromptStatus.OK) return;
            ObjectId objId = per.ObjectId;
            if (!objId.ObjectClass.IsDerivedFrom( RXClass.GetClass(typeof(Polyline))))
                ed.WriteMessage(
                    "\nYou didn't select a lwpline, please try again...\n");
                return;
            try
                using (Transaction tr = db.TransactionManager.StartTransaction())
                    Polyline pline = tr.GetObject(objId, OpenMode.ForRead, false) as Polyline;
                    if (pline != null)
                        BlockTableRecord btr = tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite, false) as BlockTableRecord;
                        Point3d pickPt = pline.GetClosestPointTo((Point3d)per.PickedPoint, false);
                        double param = pline.GetParameterAtPoint(pickPt);
                        int num = (int)param + 1;
                        ObjectId[] subentIds = { };
                        FullSubentityPath[] ips = pline.GetSubentityPathsAtGraphicsMarker(SubentityType.Edge, num, pickPt, Matrix3d.Identity, 1, subentIds);
                        pline.Highlight(ips[0], true);
                    tr.Commit();
            catch (System.Exception ex)
                ed.WriteMessage(ex.Message + "\n" + ex.StackTrace);
            finally
                ed.WriteMessage("Pokey");
~'J'~
Valued Contributor
Ertqwa
Message 3 of 8 (394 Views)
08-01-2012 11:32 AM in reply to: Hallex
Hi, ty for the response.
If I try your code,  get an error at the following line:
Error:
eNotApplicable at Autodesk.AutoCAD.DatabaseServices.Entity.Highlight(FullSubentityPath subId, Boolean highlightAll)
Trying to find out what it might be but no luck so far.
Hallex
Message 4 of 8 (390 Views)
08-01-2012 11:57 AM in reply to: Ertqwa
I tested code on A2010, it's  a reason maybe
Valued Contributor
Ertqwa
Message 5 of 8 (383 Views)
08-01-2012 01:27 PM in reply to: Hallex
Ah I see, I use AutoCAD2009. I'll do some more checking. Ty.
Hallex
Message 6 of 8 (362 Views)
08-02-2012 05:15 AM in reply to: Ertqwa
                return;
            using (tr)
                if (pline != null)
                    double bulg = 0;
                    int m = (int)par;
                        bulg = 0;
                    if (pl != null)
                if (pl != null)
                    pl.Erase();
                tr.Commit();
~'J'~
Valued Contributor
Ertqwa
Message 7 of 8 (344 Views)
08-02-2012 12:41 PM in reply to: Hallex
Hi, that works, thanks a lot!
One question tho, if I leave out the "EraseTransient" line at the end, it still disapears after I regenerate. Why should I call it?
I'll try and see if I can get the other one to work.
Hallex
Message 8 of 8 (340 Views)
08-02-2012 12:50 PM in reply to: Ertqwa
I did it machinally, though it is no problem
to keep them  inside, but who knows?
Of course, if you need to display a segment
in the work time, then don't remove,
See you,
~'J'~
