.NET
.NET
*Maksim Sestic
Post 11 of 25
Re: Hiding a Form causes entire ACAD application to lose focus (AutoCAD 2006)
01-20-2006 05:32 AM in reply to: *Maksim Sestic
It's almost
identical to example code you've sent. Here it is:
<CommandMethod("TestCommand")>
_
Public
size=2>
Sub
DisplayForm()
Dim
 Form
size=2>As
New
MyForm
class=205360014-19012006>
size=2>Autodesk.AutoCAD.ApplicationServices.Application.ShowModalDialog(Form)
color=#0000ff>
face="Courier New">End
Sub
Form has a button which hides it (
face="Courier New">Me.Hide
), but this is handled via MyForm's
class event handlers.
Even if I create
new object that displays my form within specified command handler
- it should run within defined execution context
neverthless. Could you explain what code do you consider "out of
execution context"?
Maksim Sestic
Is the code that
calls ShowModalDialog() executed from
a registered command handler, or
something else?
Your problem is most likely that your form is being
shown
by code that's running in the wrong execution context.
size=2>http://www.caddzone.com
size=2>AcadXTabs: MDI Document Tabs for AutoCAD 2004/2005/2006
href="http://www.acadxtabs.com">
size=2>http://www.acadxtabs.com
size=2>"Maksim Sestic" <
face=Verdana size=2>info@geoinova.com
wrote in message
face=Verdana size=2>news:5063409@discussion.autodesk.com
face=Verdana size=2>...
No, it didn't help. Annoying flickering (ACAD looses
focus and then regains it) still happening. It seems to me that
Autodesk.AutoCAD.ApplicationServices.Application.ShowModalDialog implementation,
which is (I believe) based on AutoCAD's Application Form, passes certain events
to it's parent without some handy overriding.
How about a third
constructor of ShowModaDialog:
Public Shared Function ShowModalDialog(ByVal
owner As System.Windows.Forms.IWin32Window, ByVal formToShow As
System.Windows.Forms.Form, ByVal persistSizeAndPosition As Boolean) As
System.Windows.Forms.DialogResult
When should I use it?
Maksim Sestic
<Jimmie Fulton> wrote
in message
face=Verdana size=2>news:5063304@discussion.autodesk.com
Does this work better for you?
Form.Visible =
False
' Do Something
Form.Visible = True
Distinguished Contributor
0 Kudos
Post 12 of 25
01-20-2006 07:21 AM in reply to: *Maksim Sestic
Maksim,
As far as the code I sent goes, if you do not want AutoCAD to handle the hiding/showing of the form, just put a me.visible=false at the beginning of the event handler, and a me.visible=true at the end of it.
Also, I have noticed the flickering, but only in explorer windows that have been opened AFTER AutoCAD has been launched. Do you see this same behavior?
C
*Maksim Sestic
Post 13 of 25
01-20-2006 09:54 AM in reply to: *Maksim Sestic
Yeah, that's it
Maksim,
C
*Tony Tanzillo
Post 14 of 25
01-20-2006 10:09 AM in reply to: *Maksim Sestic
Looks like you caught a bug. I just noticed the same
problem you cite, with my test code. It only seems to
happen with windows that are created while AutoCAD
is running.
I have no idea why they're doing this, but it certainly
isn't pretty and looks very unprofessional.
I have a bit of a problem with Autodesk not fixing API
defects, in cases where the manifestation results in
making our applications look as unprofessional as this
defect seems to do. While the defect isn't 'critical',
it makes your solutions look very unprofessional, and
that's not good.
I expect better than what we're seeing in the way of
'quirks' in the managed wrapper API.
"Maksim Sestic" wrote in message news:5064496@discussion.autodesk.com...
Tony's right, I need to pick several points (as explained in my previous post) and don't want to rely on AutoCAD showing/hiding my ModalDialog consequently. Try to reproduce that odd behaviour via:
1) Open few Explorer windows and let them remain open
2) Run AutoCAD and NETLOAD Tony's library (ACAD keeps focus)
3) Run GetPointTest command (now Form1 gets displayed and keeps focus)
4) Click the button to start points acquisition - what happens then?
4.1) Form1 gets hidden
4.2) ACAD's main window looses it's focus for a second, enough time to see opened windows in step 1)
4.3) ACAD's main window regains focus and lets you pick points...
Pretty odd behaviour.
Maksim Sestic
"Tony Tanzillo" wrote in message news:5064392@discussion.autodesk.com...
>> If you are prompting the user, you don't need to hide a form.
>> AutoCAD will hide it when you call the editor.get??? methods.
Yes it will, but if the form is already hidden, then
the GetXxxx method should do nothing.
It needs to work that way because there's cases
where I may want to prompt for several values
while the form remains hidden, so repeatedly
showing/hiding it between each successive input
request isn't going to work well in that case
(for example, the Hatch dialog's "Add Pick points"
button works like that).
A simple test (C#, with nothing but a form with
a single button and label on it) seems to confirm
that the form can be hidden and shown manually,
without relying on the call to GetPoint() to do it
for you:
using System;
using System.Drawing;
using System.Collections;
using System.ComponentModel;
using System.Windows.Forms;
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.EditorInput;
using AcadApp = Autodesk.AutoCAD.ApplicationServices.Application;
namespace ExtensionApplication1
/// Summary description for Form1.
public class Form1 : System.Windows.Forms.Form
private System.Windows.Forms.Button button1;
private System.Windows.Forms.Label label1;
/// Required designer variable.
private System.ComponentModel.Container components = null;
public Form1()
// Required for Windows Form Designer support
InitializeComponent();
// TODO: Add any constructor code after InitializeComponent call
/// Clean up any resources being used.
protected override void Dispose( bool disposing )
if( disposing )
if(components != null)
components.Dispose();
base.Dispose( disposing );
#region Windows Form Designer generated code
/// Required method for Designer support - do not modify
/// the contents of this method with the code editor.
private void InitializeComponent()
this.button1 = new System.Windows.Forms.Button();
this.label1 = new System.Windows.Forms.Label();
this.SuspendLayout();
// button1
this.button1.Location = new System.Drawing.Point(150, 66);
this.button1.Name = "button1";
this.button1.Size = new System.Drawing.Size(157, 25);
this.button1.TabIndex = 0;
this.button1.Text = "Pick points";
this.button1.Click += new System.EventHandler(this.button1_Click);
// label1
this.label1.AutoSize = true;
this.label1.Location = new System.Drawing.Point(162, 119);
this.label1.Name = "label1";
this.label1.Size = new System.Drawing.Size(35, 16);
this.label1.TabIndex = 1;
this.label1.Text = "label1";
// Form1
this.AutoScaleBaseSize = new System.Drawing.Size(5, 13);
this.ClientSize = new System.Drawing.Size(450, 182);
this.Controls.Add(this.label1);
this.Controls.Add(this.button1);
this.Name = "Form1";
this.Text = "Form1";
this.ResumeLayout(false);
#endregion
[CommandMethod("GetPointTest")]
public static void GetPointTest()
using( Form1 form = new Form1() )
AcadApp.ShowModalDialog(form);
private void button1_Click(object sender, System.EventArgs e)
Editor editor = AcadApp.DocumentManager.MdiActiveDocument.Editor;
ArrayList list = new ArrayList();
PromptPointOptions opts = new PromptPointOptions();
opts.Message = "\nNext point (or ENTER when done): ";
opts.AllowNone = true;
this.Visible = false;
try
while( true )
PromptPointResult res = editor.GetPoint(opts);
if( res.Status != PromptStatus.OK )
break;
list.Add(res.Value);
finally
this.Visible = true;
label1.Text = string.Format("{0} points picked", list.Count);
wrote in message news:5064254@discussion.autodesk.com...
Maksim,
I have created a simple project that may help you.
Let me know if it works or not.
C
*Maksim Sestic
Post 15 of 25
01-20-2006 10:40 AM in reply to: *Maksim Sestic
Tony, this one looks sooo non-critical that I'm
expecting it to get fixed in AutoCAD 2008 :-)))
Maksim Sestic
Looks like you
AutoCAD
is running.
certainly
I have a bit of
this
it
that's not good.
I
wrapper API.
face=Verdana size=2>http://www.caddzone.com
wrote in message
face=Verdana size=2>news:5064496@discussion.autodesk.com
via:
2)
3) Run GetPointTest
4.1) Form1 gets
hidden
you pick points...
Pretty odd
behaviour.
Maksim
Sestic
"Tony Tanzillo"
size=2>tony.tanzillo@U_KNOW_WHERE.com
wrote in message
face=Verdana size=2>news:5064392@discussion.autodesk.com
then
It needs to work
(for
button works like
that).
a single button
manually,
for
you:
using System;
using
System.Collections;
using
using
using
using AcadApp =
namespace
   /// <summary>
</summary>
<summary>
variable.
</summary>
      private
null;
      public
Form1()
         // TODO: Add any
call
<summary>
being used.
</summary>
         if( disposing
if(components !=
null)
/// <summary>
      /// the
/// </summary>
      private void
         this.button1 = new
this.label1 = new
button1
66);
         this.button1.Name =
"button1";
         this.button1.Size
25);
0;
points";
         this.button1.Click
+= new
label1
true;
119);
         this.label1.Name =
"label1";
         this.label1.Size =
16);
1;
         this.label1.Text =
"label1";
Form1
13);
182);
#endregion
      public static
void GetPointTest()
Form1() )
e)
         Editor editor =
ArrayList();
         opts.AllowNone =
true;
         this.Visible =
false;
try
            while(
true )
break;
finally
this.Visible =
true;
list.Count);
size=2><CougerAC> wrote in message
href="news:5064254@discussion.autodesk.com">
size=2>news:5064254@discussion.autodesk.com
size=2>...
Maksim,
you.
form.
methods.
C
3 Kudos
Post 16 of 25
11-27-2006 09:44 PM in reply to: *Maksim Sestic
Has anyone found a workaround/solution.
Regards - Nathan
*Maksim Sestic
Post 17 of 25
11-29-2006 12:10 AM in reply to: *Maksim Sestic
Not yet :-)
wrote in message news:5407830@discussion.autodesk.com...
Regards - Nathan
3 Kudos
Post 18 of 25
11-29-2006 02:13 PM in reply to: *Maksim Sestic
The problem does not occur if you minimize the windows so I tried a few approaches to do that. But they had their own problems. One approach resulted in the AutoCAD screen and my form maximised but without focus and the other that did not result in this but displayed the windows as they were minimized.
I have resigned to living with it and hope it will be fixed in 2008.
Regards - Nathan
Valued Mentor
11 Kudos
Post 19 of 25
02-25-2011 12:05 PM in reply to: *Maksim Sestic
Sorry to bring an old post back from the dead, but I was having this same issue and found this thread. I cannot beleive that I am still seeing this issue (Explorer windows opened after AutoCAD has been started flicker on form hide) in AutoCAD 2011!
As someone mentioned, this does not occur if the windows are minimized first.
6 Kudos
Post 20 of 25
05-19-2011 05:47 AM in reply to: *Maksim Sestic
i came across this thread while i was trying to solve a similar problem
I have a modal form, that shows a new modal form in a button.click event handler
    Private Sub MyButton_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MyButton.Click
        Me.Hide()
        Dim modalForm As New MyForm()
        AcApp.ShowModalDialog(modalForm)
        Me.Show()
    End Sub
after MyForm is showed, i see it's window and the background is not AutoCAD, but any application that was focused before AutoCAD
the only way to have it behave normally is to have all windows minimized, then the background for MyForm is AutoCAD
