.NET
Hide last command
5 REPLIES 5
jdsmit
301 Views, 5 Replies
Hide last command
What I need is: start my own command "like _drawline"
Then the user needs to draw a polyline.
After finishing that command i need to change something about the polyline.
And when i recall the last command it need to be '_drawline'
The most things i can do, but when i starts (with SendStringToExecute) the command '_pline', then the last command is '_pline' and it need to be '_drawline'
Is there a simple solution for this in vb.net?
Greetings Jacco
5 REPLIES 5
Keith.Brown
in reply to: jdsmit
The first and most obvious thing that comes to mind is to not use sendtostringexecute to draw a pline but instead draw the pline programatically.  There are many articles on the web on how to do this including the help file.  Below are a few links to get you started.
http://docs.autodesk.com/ACD/2013/ENU/index.html?url=files/GUID-EC036F5A-1F02-40D3-B348-4193BA58CF0C...
http://www.theswamp.org/index.php?topic=29216.0
I hope this helps.
jdsmit
in reply to: Keith.Brown
It is a possability to do this.
But what i can't do is using the function ortho on/off
I really need that.
jdsmit
in reply to: jdsmit
It works !!
The only thing now i can't is exit after the close command.
Can you help me with this?
This is my code:
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.EditorInput
Imports Autodesk.AutoCAD.Geometry
Imports Autodesk.AutoCAD.Runtime
Class JigUtils
    ' Custom ArcTangent method, as the Math.Atan
    ' doesn't handle specific cases
    Public Shared Function Atan(y As Double, x As Double) As Double
        If x > 0 Then
            Return Math.Atan(y / x)
        ElseIf x < 0 Then
            Return Math.Atan(y / x) - Math.PI
        Else
            ' x == 0
            If y > 0 Then
                Return Math.PI
            ElseIf y < 0 Then
                Return -Math.PI
            Else
                ' if (y == 0) theta is undefined
                Return 0.0
    End Function
    ' Computes Angle between current direction
    ' (vector from last vertex to current vertex)
    ' and the last pline segment
    Public Shared Function ComputeAngle(startPoint As Point3d, endPoint As Point3d, xdir As Vector3d, ucs As Matrix3d) As Double
        Dim v As New Vector3d((endPoint.X - startPoint.X) / 2, (endPoint.Y - startPoint.Y) / 2, (endPoint.Z - startPoint.Z) / 2)
        Dim cos As Double = v.DotProduct(xdir)
        Dim sin As Double = v.DotProduct(Vector3d.ZAxis.TransformBy(ucs).CrossProduct(xdir))
        Return Atan(sin, cos)
    End Function
End Class
Public Class BulgePolyJig
    Inherits EntityJig
    Private _tempPoint As Point3d
    Private _plane As Plane
    Private _isArcSeg As Boolean = False
    Private _isClose As Boolean = False
    Private _isUndoing As Boolean = False
    Private _ucs As Matrix3d
    Public Sub New(ucs As Matrix3d)
        MyBase.New(New Polyline())
        _ucs = ucs
        Dim normal As Vector3d = Vector3d.ZAxis.TransformBy(ucs)
        _plane = New Plane(Point3d.Origin, normal)
        Dim pline As Polyline = TryCast(Entity, Polyline)
        pline.SetDatabaseDefaults()
        pline.Normal = normal
        AddDummyVertex()
    End Sub
    Protected Overrides Function Sampler(prompts As JigPrompts) As SamplerStatus
        Dim jigOpts As New JigPromptPointOptions()
        jigOpts.UserInputControls = (UserInputControls.Accept3dCoordinates Or UserInputControls.NullResponseAccepted Or UserInputControls.NoNegativeResponseAccepted)
        _isUndoing = False
        If pline.NumberOfVertices = 1 Then
            ' For the first vertex, just ask for the point
            jigOpts.Message = vbLf & "Specify start point: "
        ElseIf pline.NumberOfVertices > 1 Then
            jigOpts.UserInputControls = (UserInputControls.Accept3dCoordinates Or UserInputControls.NullResponseAccepted Or UserInputControls.NoNegativeResponseAccepted Or UserInputControls.GovernedByOrthoMode)
            Dim msgAndKwds As String = (If(_isArcSeg, vbLf & "Specify endpoint of arc or [Line/Undo/Close]: ", vbLf & "Specify next point or [Arc/Undo/Close]: "))
            Dim kwds As String = (If(_isArcSeg, "Line Undo Close", "Arc Undo Close"))
            jigOpts.SetMessageAndKeywords(msgAndKwds, kwds)
        Else
            Return SamplerStatus.Cancel
        ' Should never happen
        ' Get the point itself
        Dim res As PromptPointResult = prompts.AcquirePoint(jigOpts)
        If res.Status = PromptStatus.Keyword Then
            If res.StringResult.ToUpper() = "ARC" Then
                _isArcSeg = True
            ElseIf res.StringResult.ToUpper() = "LINE" Then
                _isArcSeg = False
            ElseIf res.StringResult.ToUpper() = "UNDO" Then
                _isUndoing = True
            ElseIf res.StringResult.ToUpper() = "CLOSE" Then
                _isClose = True
            Return SamplerStatus.OK
        ElseIf res.Status = PromptStatus.OK Then
            ' Check if it has changed or not (reduces flicker)
            If _tempPoint = res.Value Then
                Return SamplerStatus.NoChange
            Else
    End Function
    Protected Overrides Function Update() As Boolean
        ' Update the dummy vertex to be our 3D point
        ' projected onto our plane
        Dim pl As Polyline = TryCast(Entity, Polyline)
        If _isArcSeg Then
            Dim lastVertex As Point3d = pl.GetPoint3dAt(pl.NumberOfVertices - 2)
            Dim refDir As Vector3d
            If pl.NumberOfVertices < 3 Then
                refDir = New Vector3d(1.0, 1.0, 0.0)
            Else
                ' Check bulge to see if last segment was an arc or a line
                If pl.GetBulgeAt(pl.NumberOfVertices - 3) <> 0 Then
                    Dim arcSegment As CircularArc3d = pl.GetArcSegmentAt(pl.NumberOfVertices - 3)
                    Dim tangent As Line3d = arcSegment.GetTangent(lastVertex)
                    ' Reference direction is the invert of the arc tangent
                    ' at last vertex
                    refDir = tangent.Direction.MultiplyBy(-1.0)
                Else
                    Dim pt As Point3d = pl.GetPoint3dAt(pl.NumberOfVertices - 3)
                    refDir = New Vector3d(lastVertex.X - pt.X, lastVertex.Y - pt.Y, lastVertex.Z - pt.Z)
            Dim angle As Double = JigUtils.ComputeAngle(lastVertex, _tempPoint, refDir, _ucs)
            ' Bulge is defined as tan of one fourth of included angle
            ' Need to double the angle since it represents the included
            ' angle of the arc
            ' So formula is: bulge = Tan(angle * 2 * 0.25)
            Dim bulge As Double = Math.Tan(angle * 0.5)
            pl.SetBulgeAt(pl.NumberOfVertices - 2, bulge)
        Else
            ' Line mode. Need to remove last bulge if there was one
            If pl.NumberOfVertices > 1 Then
                pl.SetBulgeAt(pl.NumberOfVertices - 2, 0)
        pl.SetPointAt(pl.NumberOfVertices - 1, _tempPoint.Convert2d(_plane))
        Return True
    End Function
    Public ReadOnly Property IsUndoing() As Boolean
        Get
            Return _isUndoing
        End Get
    End Property
    Public ReadOnly Property IsClose() As Boolean
        Get
            Return _isClose
        End Get
    End Property
    Public Sub AddDummyVertex()
        ' Create a new dummy vertex... can have any initial value
        pline.AddVertexAt(pline.NumberOfVertices, New Point2d(0, 0), 0, 0, 0)
    End Sub
    Public Sub RemoveLastVertex()
        ' Let's first remove our dummy vertex
        If pline.NumberOfVertices > 0 Then
            pline.RemoveVertexAt(pline.NumberOfVertices - 1)
        ' And then check the type of the last segment
        If pline.NumberOfVertices >= 2 Then
            Dim blg As Double = pline.GetBulgeAt(pline.NumberOfVertices - 2)
            _isArcSeg = (blg <> 0)
    End Sub
    Public Sub CloseVertex()
        pline.Closed = True
    End Sub
    Public Sub Append()
        Dim db As Database = HostApplicationServices.WorkingDatabase
        Dim tr As Transaction = db.TransactionManager.StartTransaction()
        Using tr
            Dim bt As BlockTable = TryCast(tr.GetObject(db.BlockTableId, OpenMode.ForRead), BlockTable)
            Dim btr As BlockTableRecord = TryCast(tr.GetObject(bt(BlockTableRecord.ModelSpace), OpenMode.ForWrite), BlockTableRecord)
            btr.AppendEntity(Me.Entity)
            tr.AddNewlyCreatedDBObject(Me.Entity, True)
            tr.Commit()
        End Using
    End Sub
    <CommandMethod("mp")> _
    Public Shared Sub RunBulgePolyJig()
        Dim doc As Document = Application.DocumentManager.MdiActiveDocument
        Dim db As Database = doc.Database
        Dim ed As Editor = doc.Editor
        Dim jig As New BulgePolyJig(ed.CurrentUserCoordinateSystem)
        While True
            Dim res As PromptResult = ed.Drag(jig)
            Select Case res.Status
                ' New point was added, keep going
                Case PromptStatus.OK
                    jig.AddDummyVertex()
                    Exit Select
                    ' Keyword was entered
                Case PromptStatus.Keyword
                    If jig.IsUndoing Then
                        jig.RemoveLastVertex()
                    If jig.IsClose Then
                        jig.CloseVertex()
                    Exit Select
                    ' If the jig completed successfully, add the polyline
                Case PromptStatus.None
                    jig.Append()
                    Return
                Case Else
                    ' User cancelled the command, get out of here
                    ' and don't forget to dispose the jigged entity
                    jig.Entity.Dispose()
                    Return
            End Select
        End While
    End Sub
End Class
hgasty1001
in reply to: jdsmit
As you just copied the code from Kean's blog, maybe you just try asking there for support.
Gaston Nunez
jdsmit
in reply to: hgasty1001
I used the code in C#, change it it vb.net and add some features in it.
I was hoping that someone can help me with this feature close.
”Boost
