.NET
luisibad
Message 1 of 5 (341 Views)
Help with Ribbon
341 Views, 4 Replies
12-01-2013 03:50 AM
Hi! I need help with this.
I've created my routines in VB.NET obviously with a lot help from this forum, I mean  following a lot of post, even I've created my panel ribbon and so far so good.
But now I would like to learn how to interact (enable) my ribbon button with my routine, because my ribbon button doesn't work for it. I was looking information about it, and I saw that I must use xlm code, and really I don't how to do it, because all information that I found is about C# code and my knowlege is about VB.NET
really I'll apreciate all help about it
try adding <space> or ";" or <enter> to the command
RibBtnPoints.CommandParameter = "PUNTOS "
RibBtnPoints.CommandParameter = "PUNTOS;"
RibBtnPoints.CommandParameter = "PUNTOS" + vbCR
Look in youre CUI, the LINE command below contains a extra <space>
ADN Support Specialist
Balaji_Ram
Message 2 of 5 (285 Views)
Re: Help with Ribbon
12-23-2013 01:19 AM in reply to: luisibad
Sorry for the delay.
Can you please explain what you mean by
"how to interact (enable) my ribbon button with my routine, because my ribbon button doesn't work for it"
If you can share some sample code that you have along with screenshots to explain what you are trying, that will help.
If you want to show / hide the ribbon panels, this blog post can provide a sample code :
http://adndevblog.typepad.com/autocad/2012/07/modify-ribbon.html
Balaji
Balaji
Developer Technical Services
Autodesk Developer Network
luisibad
Message 3 of 5 (263 Views)
12-26-2013 02:08 AM in reply to: Balaji_Ram
Hi! Thanks for answer.
I created my routine in VB.NET
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.Windows
Imports System.Windows.Forms
<Assembly: CommandClass(GetType(frmImportPointsVB.ClsDrawPoints))>
Namespace frmImportPointsVB
   PublicClassClsDrawPoints
     'This is my command and through  of this I load a form
     <CommandMethod("PUNTOS", CommandFlags.Modal)>
     PublicSharedSub InitForm()
        Dim frm AsNewfrmImportPoints
        Dim Result AsDialogResult = Autodesk.AutoCAD.ApplicationServices.Application.ShowModalDialog(frm)
     EndSub
   EndClass
EndNamespace
I can load it without problems in AutoCAD and It works. As you can see it in the picture Captura1.
Later I have the next code to create the control ribbon:
PublicClassClsRibbon
ImplementsIExtensionApplication
  PublicSub Initialize() ImplementsIExtensionApplication.Initialize
      CreateRibbon()
  EndSub
  PublicSub Terminate() ImplementsIExtensionApplication.Terminate
  EndSub
  PrivateSub CreateRibbon()
    Dim RibCtrl AsRibbonControl = ComponentManager.Ribbon
    Dim RibTab AsNewRibbonTab()
    RibTab.Title = "IBAD_2014"
    RibTab.Id = "IBAD_2014"
        RibCtrl.Tabs.Add(RibTab)
    RibTab.IsActive = True
        AddContent(RibTab)
  EndSub
  PrivateSub AddContent(ByVal RibTab AsRibbonTab)
    Dim RibSourcePanel AsRibbonPanelSource = NewRibbonPanelSource()
    RibSourcePanel.Title = "Herramientas"
    Dim RibPanel AsNewRibbonPanel()
        RibPanel.Source = RibSourcePanel
        RibTab.Panels.Add(RibPanel)
    Dim ribToolTip AsRibbonToolTip = NewRibbonToolTip
    ribToolTip.Title = "My Title"
    ribToolTip.Content = "My Content"
    ribToolTip.ExpandedContent = "my Expanded Content !"
    ribToolTip.IsHelpEnabled = False
   'Boton Ribbon para el dibujo de los PUNTOS
    Dim RibBtnPoints AsRibbonButton = NewRibbonButton()
    RibBtnPoints.Text = "DIBUJAR PUNTOS"
    RibBtnPoints.ShowText = True
    RibBtnPoints.LargeImage = LoadImage(My.Resources.Resource1.In_Point_32px)
    RibBtnPoints.Orientation = Windows.Controls.Orientation.Vertical
    RibBtnPoints.ShowImage = True
    RibBtnPoints.Size = RibbonItemSize.Large
    RibBtnPoints.CommandHandler = NewAdskCommandHandler()
    RibBtnPoints.IsToolTipEnabled = True
       RibBtnPoints.ToolTip = ribToolTip
   'Botón Ribbon para el dibujo del PERFIL LONGITUDINAL
   Dim RibBtnPerfil AsRibbonButton = NewRibbonButton()
   RibBtnPerfil.Text = "DIBUJAR PERFIL"
   RibBtnPerfil.CommandParameter = "PERFILES"
   RibBtnPerfil.ShowText = True
   RibBtnPerfil.LargeImage = LoadImage(My.Resources.Resource1.Profile_32px)
   RibBtnPerfil.Orientation = Windows.Controls.Orientation.Vertical
   RibBtnPerfil.ShowImage = True
   RibBtnPerfil.Size = RibbonItemSize.Large
   RibBtnPerfil.CommandHandler = NewAdskCommandHandler()
  'Botón Ribbon para extraer attributos de los BLOQUES y exportarlos EXCEL
   Dim RibBtnExport AsRibbonButton = NewRibbonButton()
   RibBtnExport.Text = "EXPORTAR ATRIBUTOS"
   RibBtnExport.CommandParameter = "EXPORTAR_ATT"
   RibBtnExport.ShowText = True
   RibBtnExport.LargeImage = LoadImage(My.Resources.Resource1.Out_Point_32px)
   RibBtnExport.Orientation = Windows.Controls.Orientation.Vertical
   RibBtnExport.ShowImage = True
   RibBtnExport.Size = RibbonItemSize.Large
   RibBtnExport.CommandHandler = NewAdskCommandHandler()
      RibSourcePanel.Items.Add(RibBtnPoints)
   RibSourcePanel.Items.Add(NewRibbonSeparator)
      RibSourcePanel.Items.Add(RibBtnPerfil)
      RibSourcePanel.Items.Add(RibBtnExport)
 EndSub
PublicClassAdskCommandHandler
 Implements System.Windows.Input.ICommand
  PublicFunction CanExecute(parameter AsObject) AsBooleanImplements Windows.Input.ICommand.CanExecute
   ReturnTrue
  EndFunction
  PublicEvent CanExecuteChanged(sender AsObject, e AsEventArgs) Implements Windows.Input.ICommand.CanExecuteChanged
  PublicSub Execute(parameter AsObject) Implements Windows.Input.ICommand.Execute
   Dim RibBtn AsRibbonButton = TryCast(parameter, RibbonButton)
    If RibBtn IsNotNothingThen
       Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.
       SendStringToExecute(RibBtn.CommandParameter, True, False, True)
    EndIf
  EndSub
EndClass
And so far so good, because appear the ribbon in AutoCAD. As you can see it in the picture Captura2.
And my problem is in this part. When I click in the button doesn't work I mean doesn't load my form, It just appear in the command line the name of my command "PUNTOS". As you can see it in the picture Capture3.
I was reading a lot about it and I couldn't find some solution, I guess I should learn something  about XAML, and really I don't have experience with it.
I would appreciate any help about it. Thanks.
SENL1362
Message 4 of 5 (259 Views)
12-26-2013 02:21 AM in reply to: luisibad
luisibad
Message 5 of 5 (250 Views)
12-26-2013 02:51 AM in reply to: luisibad
Thanks you! it works with vbCr....
