.NET
Help with getting code to run with DoccumentActivated
2 REPLIES 2
Davidgun64
311 Views, 2 Replies
Hello
I am trying to get some code to run whenever the active documents changes.  As far as I can tell the code below should run when I load my app however it does not.  I was able to get similar code to run copied from the .net devlopers guide but thier example involved the user runing a command to run the AddHandler part which is not what i want.
any help is appreciated.
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.ApplicationServices
Public Class CurrentDrawing
    Implements IExtensionApplication
    Public Sub Initialize() Implements IExtensionApplication.Initialize
        AddHandler Application.DocumentManager.DocumentActivated, AddressOf docColDocAct
    End Sub
    Public Sub Terminate() Implements IExtensionApplication.Terminate
    End Sub
    Public Sub docColDocAct(ByVal senderObj As Object, ByVal docColDocActEvtArgs _
                            As DocumentCollectionEventArgs)
        Application.ShowAlertDialog(docColDocActEvtArgs.Document.Name & " was activated.")
    End Sub
End Class
2 REPLIES 2
you have created a class that is derived from IExtensionApplication but AutoCAD will not call it. So you are missing the part that tells AutoCAD that there is an initialization-part.
Practically this means you have to add this line under your imports:
<Assembly: Autodesk.AutoCAD.Runtime.ExtensionApplication(GetType(CurrentDrawing))>
The red part may have to be exchanged to the fill NameSpace-name of your class-definition-name. With this statement AutoCAD knows there is an initialization part to run and it will do that when you NETLOAD your app.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Davidgun64
in reply to: Davidgun64
Thanks!  got it working now.
”Boost
