.NET
Help with CAO GetLinks() function
1 REPLY 1
wesbird
670 Views, 1 Reply
I got a problem to run CAO GetLinks in C# and get a error message:
"The parameter is incorrect."
and I found a solution from ObjectARX group
http://discussion.autodesk.com/thread.jspa?messageID=398629
but I am not good at ObjectARX, can someone help me fix this problem?
here is my code:
// Remove Link
public static void RemoveLink(ObjectId objId, string LT_name, string KeyValue)
CAO.DbConnect odbConnect;
Autodesk.AutoCAD.Interop.AcadApplication acadApp;
Autodesk.AutoCAD.Interop.AcadDocument acadDoc;
Editor ed = Application.DocumentManager.MdiActiveDocument.Editor;
acadApp = (Autodesk.AutoCAD.Interop.AcadApplication)Autodesk.AutoCAD.ApplicationServices.Application.AcadApplication;
acadDoc = acadApp.ActiveDocument;
// if (odbConnect == null )
try
if (acadApp != null)
odbConnect = (CAO.DbConnect)acadApp.GetInterfaceObject("CAO.DbConnect.16");
CAO.LinkTemplates LTs = odbConnect.GetLinkTemplates(acadDoc);
CAO.LinkTemplate LT;
try
LT = LTs.Item(LT_name);
catch(System.Exception caught)
ed.WriteMessage(caught.ToString());
return;
long[] ObjIds = new long[1];
ObjIds[0] = objId.OldId;
// CAO.Links Links = odbConnect.GetLinks(LT, ObjIds, (int)CAO.LinkType.kEntityLinkType,acadDoc);
CAO.Links Links = odbConnect.GetLinks(LT, ObjIds, 2,acadDoc);
foreach (CAO.Link link in Links)
CAO.KeyValues kvs = link.KeyValues;
foreach (CAO.KeyValue kv in kvs)
if ((string)kv.Value == KeyValue)link.Delete();
catch (System.Exception caught)
ed.WriteMessage(caught.Message.ToString());
Wes Message was edited by: weslleywang
Windows 10 64 bit, AutoCAD (ACA, Map) 2023
1 REPLY 1
Daniel.Du
in reply to: wesbird
you need to pass parameter with object type,  try following code snippet, pay attention to the type converting:
CAO.Links Links = odbConnect.GetLinks(LT,(object) ObjIds, 2,acadDoc);
Daniel Du
Developer Technical Services
Autodesk Developer Network
”Boost
