.NET
.NET
Member
0 Kudos
Post 1 of 9
Help with 6A221957-2D85-42A7-8E19-BE33950D1DEB - Class not registered
262 Views, 8 Replies
04-17-2014 06:15 AM
Forgive me, I'm a rather complete newbie to this, so I may be barking up the wrong tree, or asking in the wrong place, but here goes.
I've been tasked with updating an in-house app, originally written in VB6, now being maintained in VB.NET (Visual Studio 2010).
First thing I need to do is to be able to simply open a Autocad file when the user clicks on a button. (Note, this functionality works in the older code, with Autocad 2009).
So far I have:
Imports Autodesk.AutoCAD.Interop.Common
Public AcadDoc As AutoCAD.Interop.AcadDocument = New AutoCAD.Interop.AcadDocument
Public ACADapp As AutoCAD.Interop.AcadApplication = New AutoCAD.Interop.AcadApplication
Public ACADmod As AutoCAD.Interop.Common.AcadModelSpace = New AutoCAD.Interop.Common.AcadModelSpace
This breaks however before I even get to the code to do anything.  The first declaration fails with:
Retrieving the COM class factory for component with CLSID {6A221957-2D85-42A7-8E19-BE33950D1DEB} failed due to the following error: 80040154 Class not registered (Exception from HRESULT: 0x80040154 (REGDB_E_CLASSNOTREG)).
My first guess would be needing to register the DLLs, but when I try, I get an error:
The module Autodesk.AutoCad.Interop.Commonl.dll was loaded, but the entry-poin DLLRegisterServer was not found, etc.
I have Autodesk Inventor 2013 on machine, but the users will have Autocad 2013 itself installed.
I have alos downloaded and installed ObjectARX 2013 (and in fact that's where the DLLs are being loaded from in theory.)
I'm assuming I'm making a rookie mistake here.
(I'm also unclear if this is the proper way moving forward or if the newer dlls with 2013 should be used instead.)
Thanks for any help you can give.
One more thing to add if it makes a differences:
Because of a reliance on another 3rd party DLL, I have to build this app as an x86 app. I can't use "Any" or x64.
You did not mention, but I guess the application you are doing (ro converting from VB6) is an stand-alone EXE app. IMO, automating AutoCAD from external EXE app is not a best type of application in most cases. But you may have good reason to do so. No more comment on this without knowing more details.
However, the error you ran into is not due to any reason you have discussed in the the thread. The reason of error is:
You CANNOT "New" a AcadDocument, NOR you can "NEW" AcadModelSpace.
You can only create a new AcadDocument instance by AcadDocuments.Open()/Add().
That is, you first obtain an AcadApplication instance, which is "New"-able class. That you do something like
AcadDocument doc=acadApp.Documents.Open("...") or
AcadDocument doc=AcadApp.Documents.Add("...")
Once you have an instance of an AcadDocument, you can reach the MOdelSpace of the drawing by
doc.ModelSpace
Distinguished Mentor
91 Kudos
Post 2 of 9
Re: Help with 6A221957-2D85-42A7-8E19-BE33950D1DEB - Class not registered
04-17-2014 07:32 AM in reply to: Greg.Moore
You have a problem, interop it's platform dependent (32 xor 64), so you have few alternatives:
1.-Add references to the dlls included in the Inc-win32 folder of the SDK
2.-Use late binding or dynamic loading the dll
3.-Do not use interop at all (prefered solution), there are very few (if any) things that you can not do with the managed API
You can find some examples of late binding here:Late Binding
Gaston Nunez
Member
0 Kudos
Post 3 of 9
04-17-2014 07:50 AM in reply to: gasty1001
Gaston Nunez
Thanks.  In reference to option #1: I am including the references to exactly those DLLs.
e.g.:
Autodesk.AutoCAD.Interop points to: C:\ObjectARX 2013\inc-win32\Autodesk.AutoCAD.Interop.dll
Autodesk.AutoCAD.Interop.Common points to C:\ObjectARX 2013\inc-win32\Autodesk.AutoCAD.Interop.Common.dll
As for option #2, I'd prefer to avoid that.
Actually option #3 is my preferred solution also (even if it means a lot more work) since I want this app to be forward compatible.
I tried the code example here:
http://docs.autodesk.com/ACD/2013/ENU/index.html?url=files/GUID-330A8DCB-626F-4271-8B89-9773A7631D87...
But get the error others have received:
Which this post seems to give a solution to:
http://forums.autodesk.com/t5/NET/Open-is-not-a-member-of-ApplicationServices-DocumentCollection/td-...
So, I've decided to reduce this to a simple problem and see if I can open a DWG in the simplest project available:
I have:
Imports System.IO
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.Runtime
Dim strfilename As String = "C:\test.dwg"
MsgBox("this will open file: " & strfilename)
Dim acDoc As DocumentCollection
If (File.Exists(strfilename)) Then
   DocumentCollectionExtension.Open(acDoc, strfilename, False)
Else
   'acDocMgr.MdiActiveDocument.Editor.WriteMessage("File " & strfilename & " does not exist.")
End If
And get
Common Language Runtime detected an invalid program.
I'm guessing it's because it's somehow not properly finding autocad (or in my case, autocad inventor)?
Again, thanks for the help.
91 Kudos
Post 4 of 9
04-17-2014 08:29 AM in reply to: Greg.Moore
What you mean by "m guessing it's because it's somehow not properly finding autocad..."?, if you are trying to use that code in AutoCAD, you should first netload the dll, if you are trying that code from an external exe, it wont work as managed code *need* to be netloaded in AutoCAD.
Gaston Nunez
Member
0 Kudos
Post 5 of 9
04-17-2014 08:36 AM in reply to: gasty1001
Yeah, this is an external application.
So I'm not sure what you mean by "it wont work as managed code *need* to be netloaded in AutoCAD"
Basically the end solution is I need an external app that will open an autocad drawing (with autocad 2013).
An older version of this external app does work with autocad 2009. I need to update it to work with 2013.
Like I say, I may be barking up the wrong tree (heck I may be in the wrong forest :-)
91 Kudos
Post 6 of 9
04-17-2014 08:50 AM in reply to: Greg.Moore
May I'm wrong but I think that any code that use the standar dll (AcMgd,AcdbMgd, and AcCoreMgd) need to be loaded in the AutoCAD process space, an external application it's an out of process (in reference to AutoCAD), so I think there is no way (perhaps using some obscure hack) to do that. So you have to reformulate the architecture of the application.
Gaston Nunez
Member
0 Kudos
Post 7 of 9
04-17-2014 08:53 AM in reply to: gasty1001
Thanks. No, I think you're right. I think I'm back to going with option #1.
217 Kudos
Post 8 of 9
04-17-2014 09:23 AM in reply to: Greg.Moore
doc.ModelSpace
Member
0 Kudos
Post 9 of 9
04-17-2014 09:37 AM in reply to: norman.yuan
Bingo!
That solves that particular problem.
(Running into new ones, but I'll open a separate thread for that.)
I'm so used to assigning something (usually a "new" ) when defining stuff I added that into the code and never thought about it.
 I'm a step closer to where I need to be.
Thanks.
