.NET
luisibad
Message 1 of 2 (159 Views)
Help to insert block with 3 atrtibutes
159 Views, 1 Replies
04-21-2013 03:01 AM
Sorry for my english, I created one code to insert one Block and this block has 3 attributes
Dim AcadDocPt AsDocument = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
Dim AcadCurrentDBPt AsDatabase = AcadDocPt.Database
'Values Ptx, Pty, Ptz will use to insert block
Dim PtX, PtY, PtZ As Double
'Values NPt, Cota, Descripcion will use to attributes
'Just forget about Valores because will cacth value from .txt
Dim NPt, Cota, Descripcion As String
                NPt = Valores(0)
                PtY = Convert.ToDouble(Valores(1))
                PtX = Convert.ToDouble(Valores(2))
                PtZ = Convert.ToDouble(Valores(3))
                Cota = Valores(3)
                Descripcion = Valores(4)
Using AcadTransPt AsTransaction = AcadCurrentDBPt.TransactionManager.StartTransaction()
Dim BloqueName AsString = txtName.Text() 'Forget this value too, because will cacth value from form
Dim AcadBlkTblIns AsBlockTable
                    AcadBlkTblIns = AcadTransPt.GetObject(AcadCurrentDBPt.BlockTableId,OpenMode.ForRead)
If AcadBlkTblIns.Has(BloqueName) Then
Dim AcadBlockRec AsBlockTableRecord
AcadBlockRec = AcadTransPt.GetObject(AcadBlkTblIns(BlockTableRecord.ModelSpace),OpenMode.ForWrite)
Dim AcadBlock AsBlockTableRecord
 AcadBlock = AcadTransPt.GetObject(AcadBlkTblIns.Item(BloqueName),OpenMode.ForRead, False)
'In this line I can insert the block using the values: Ptx, Pty and Ptz.... that will be obtain from file .txt........ and it works because I can se the blocks inserted in Autocad....
Dim AcadBlockRef AsNewBlockReference(NewPoint3d(PtX, PtY, PtZ), AcadBlock.ObjectId)
'I would like to create here code to insert attibutes to the block... because
The block has 3 attributes to use.... help in this part because I just found
out information, but didn't help to my propose. please pay attention the block has 3 attributes and the values for then are: PNt, Cota and Descripcion. again sorry for my english. Thanks
AcadBlockRec.AppendEntity(AcadBlockRef)
AcadTransPt.AddNewlyCreatedDBObject(AcadBlockRef,True)
AcadTransPt.Commit()
EndIf
EndUsing
*Expert Elite*
Hallex
Message 2 of 2 (131 Views)
Re: Help to insert block with 3 atrtibutes
04-21-2013 08:00 AM in reply to: luisibad
Here is code from my oldies,
change list of tags and values and the block name
to your suit
        Private Shared Sub ApplyAttibutes(ByRef db As Database, ByRef tr As Transaction, ByVal bref As BlockReference, ByVal listTags As List(Of String), ByVal listValues As List(Of String))
            Dim btr As BlockTableRecord = DirectCast(tr.GetObject(bref.BlockTableRecord, OpenMode.ForRead), BlockTableRecord)
            For Each attId As ObjectId In btr
                Dim ent As Entity = DirectCast(tr.GetObject(attId, OpenMode.ForRead), Entity)
                If TypeOf ent Is AttributeDefinition Then
                    Dim attDef As AttributeDefinition = DirectCast(ent, AttributeDefinition)
                    Dim attRef As New AttributeReference()
                    attRef.SetAttributeFromBlock(attDef, bref.BlockTransform)
                    bref.AttributeCollection.AppendAttribute(attRef)
                    tr.AddNewlyCreatedDBObject(attRef, True)
                    If listTags.Contains(attDef.Tag) Then
                        Dim found As Integer = listTags.BinarySearch(attDef.Tag)
                        If found >= 0 Then
                            attRef.TextString = listValues(found)
                            attRef.AdjustAlignment(db)
            Next
        End Sub
        <CommandMethod("iab")> _
        Public Shared Sub testAttributedBlockInsert()
            Dim doc As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
            Dim db As Database = doc.Database
            Dim ed As Editor = doc.Editor
            ' change block name to your suit
            Dim blockName As String = "UserName"
            Dim ucs As Matrix3d = ed.CurrentUserCoordinateSystem 'get current UCS matrix
            Try
                Using tr As Transaction = db.TransactionManager.StartTransaction()
                    ' to force update drawing screen
                    doc.TransactionManager.EnableGraphicsFlush(True)
                    Dim bt As BlockTable = DirectCast(tr.GetObject(db.BlockTableId, OpenMode.ForWrite), BlockTable)
                    ' if the block table doesn't already exists, exit
                    If Not bt.Has(blockName) Then
                        Autodesk.AutoCAD.ApplicationServices.Application.ShowAlertDialog("Block " & blockName & " does not exist.")
                        Return
                    ' insert the block in the current space
                    Dim ppr As PromptPointResult = ed.GetPoint(vbLf & "Specify insertion point: ")
                    If ppr.Status <> PromptStatus.OK Then
                        Return
                    Dim btr As BlockTableRecord = DirectCast(tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite), BlockTableRecord)
                    Dim occ As ObjectContextCollection = db.ObjectContextManager.GetContextCollection("ACDB_ANNOTATIONSCALES")
                    Dim pt As Point3d = ppr.Value
                    Dim bref As New BlockReference(pt, bt(blockName))
                    bref.TransformBy(ucs)
                    bref.AddContext(occ.CurrentContext)
                    'add blockreference to current space
                    btr.AppendEntity(bref)
                    tr.AddNewlyCreatedDBObject(bref, True)
                    ' set attributes to desired values
                    ApplyAttibutes(db, tr, bref, New List(Of String)(New String() {"TAG1", "TAG2", "TAG3", "TAG4"}), New List(Of String)(New String() {"Value #1", "Value #2", "Value #3", "Value #4"}))
                    bref.RecordGraphicsModified(True) ' to force updating a block reference
                    tr.TransactionManager.QueueForGraphicsFlush()
                    tr.Commit()
                End Using
            Catch ex As Autodesk.AutoCAD.Runtime.Exception
                Autodesk.AutoCAD.ApplicationServices.Application.ShowAlertDialog(ex.Message)
            Finally
                ' Autodesk.AutoCAD.ApplicationServices.Application.ShowAlertDialog("Pokey")
            End Try
        End Sub
_____________________________________
C6309D9E0751D165D0934D0621DFF27919
Post to the Community
New Post
Announcements
Are You Going To Be @ AU 2014? Feel free to drop by our AU topic post and share your plans, plug a class that you're teaching, or simply check out who else from the community might be in attendance. Ohh and don't forgot to stop by the Autodesk Help | Learn | Collaborate booths in the Exhibit Hall and meet our community team if you get a chance!
