Sorry for my english, I created one code to insert one Block and this block has 3 attributes
Dim AcadDocPt AsDocument = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
Dim AcadCurrentDBPt AsDatabase = AcadDocPt.Database
'Values Ptx, Pty, Ptz will use to insert block
Dim PtX, PtY, PtZ As Double
'Values NPt, Cota, Descripcion will use to attributes
'Just forget about Valores because will cacth value from .txt
Dim NPt, Cota, Descripcion As String
NPt = Valores(0)
PtY = Convert.ToDouble(Valores(1))
PtX = Convert.ToDouble(Valores(2))
PtZ = Convert.ToDouble(Valores(3))
Cota = Valores(3)
Descripcion = Valores(4)
Using AcadTransPt AsTransaction = AcadCurrentDBPt.TransactionManager.StartTransaction()
Dim BloqueName AsString = txtName.Text() 'Forget this value too, because will cacth value from form
Dim AcadBlkTblIns AsBlockTable
AcadBlkTblIns = AcadTransPt.GetObject(AcadCurrentDBPt.BlockTableId,OpenMode.ForRead)
If AcadBlkTblIns.Has(BloqueName) Then
Dim AcadBlockRec AsBlockTableRecord
AcadBlockRec = AcadTransPt.GetObject(AcadBlkTblIns(BlockTableRecord.ModelSpace),OpenMode.ForWrite)
Dim AcadBlock AsBlockTableRecord
AcadBlock = AcadTransPt.GetObject(AcadBlkTblIns.Item(BloqueName),OpenMode.ForRead, False)
'In this line I can insert the block using the values: Ptx, Pty and Ptz.... that will be obtain from file .txt........ and it works because I can se the blocks inserted in Autocad....
Dim AcadBlockRef AsNewBlockReference(NewPoint3d(PtX, PtY, PtZ), AcadBlock.ObjectId)
'I would like to create here code to insert attibutes to the block... because
The block has 3 attributes to use.... help in this part because I just found
out information, but didn't help to my propose. please pay attention the block has 3 attributes and the values for then are: PNt, Cota and Descripcion. again sorry for my english. Thanks
AcadBlockRec.AppendEntity(AcadBlockRef)
AcadTransPt.AddNewlyCreatedDBObject(AcadBlockRef,True)
AcadTransPt.Commit()
EndIf
EndUsing
Here is code from my oldies,
change list of tags and values and the block name
to your suit
Private Shared Sub ApplyAttibutes(ByRef db As Database, ByRef tr As Transaction, ByVal bref As BlockReference, ByVal listTags As List(Of String), ByVal listValues As List(Of String)) Dim btr As BlockTableRecord = DirectCast(tr.GetObject(bref.BlockTableRecord, OpenMode.ForRead), BlockTableRecord) For Each attId As ObjectId In btr Dim ent As Entity = DirectCast(tr.GetObject(attId, OpenMode.ForRead), Entity) If TypeOf ent Is AttributeDefinition Then Dim attDef As AttributeDefinition = DirectCast(ent, AttributeDefinition) Dim attRef As New AttributeReference() attRef.SetAttributeFromBlock(attDef, bref.BlockTransform) bref.AttributeCollection.AppendAttribute(attRef) tr.AddNewlyCreatedDBObject(attRef, True) If listTags.Contains(attDef.Tag) Then Dim found As Integer = listTags.BinarySearch(attDef.Tag) If found >= 0 Then attRef.TextString = listValues(found) attRef.AdjustAlignment(db) End If End If End If Next End Sub <CommandMethod("iab")> _ Public Shared Sub testAttributedBlockInsert() Dim doc As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument Dim db As Database = doc.Database Dim ed As Editor = doc.Editor ' change block name to your suit Dim blockName As String = "UserName" Dim ucs As Matrix3d = ed.CurrentUserCoordinateSystem 'get current UCS matrix Try Using tr As Transaction = db.TransactionManager.StartTransaction() ' to force update drawing screen doc.TransactionManager.EnableGraphicsFlush(True) Dim bt As BlockTable = DirectCast(tr.GetObject(db.BlockTableId, OpenMode.ForWrite), BlockTable) ' if the block table doesn't already exists, exit If Not bt.Has(blockName) Then Autodesk.AutoCAD.ApplicationServices.Application.ShowAlertDialog("Block " & blockName & " does not exist.") Return End If ' insert the block in the current space Dim ppr As PromptPointResult = ed.GetPoint(vbLf & "Specify insertion point: ") If ppr.Status <> PromptStatus.OK Then Return End If Dim btr As BlockTableRecord = DirectCast(tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite), BlockTableRecord) Dim occ As ObjectContextCollection = db.ObjectContextManager.GetContextCollection("ACDB_ANNOTATIONSCALES") Dim pt As Point3d = ppr.Value Dim bref As New BlockReference(pt, bt(blockName)) bref.TransformBy(ucs) bref.AddContext(occ.CurrentContext) 'add blockreference to current space btr.AppendEntity(bref) tr.AddNewlyCreatedDBObject(bref, True) ' set attributes to desired values ApplyAttibutes(db, tr, bref, New List(Of String)(New String() {"TAG1", "TAG2", "TAG3", "TAG4"}), New List(Of String)(New String() {"Value #1", "Value #2", "Value #3", "Value #4"})) bref.RecordGraphicsModified(True) ' to force updating a block reference tr.TransactionManager.QueueForGraphicsFlush() tr.Commit() End Using Catch ex As Autodesk.AutoCAD.Runtime.Exception Autodesk.AutoCAD.ApplicationServices.Application.ShowAlertDialog(ex.Message) Finally ' Autodesk.AutoCAD.ApplicationServices.Application.ShowAlertDialog("Pokey") End Try End Sub
