.NET
Help on Starting .NET
2 REPLIES 2
HJohn
177 Views, 2 Replies
I downloaded the AutoCAD 2007.NET training file. In the PPT, slide 38, Loading .NET assembly, shows a bunch of registry entries. Can someone explain why are these needed. I created a test assembly and loaded it using NETLOAD, everything seems to be ok, no registry entries added. I don't know why are these entries required or its benefits.
2 REPLIES 2
in reply to: HJohn
See
http://through-the-interface.typepad.com/through_the_interface/2006/09/automatic_loadi.html
Dan
wrote in message news:5335910@discussion.autodesk.com...
HJohn
in reply to: HJohn
Thank you very much Dan, the info was of great help
”Boost
