.NET
Help needed for sample code on File -> Export Layout to Modelspace dwg
0 REPLIES 0
Message 1 of 1
bob53050
251 Views, 0 Replies
The use case for this is to open an Inventor dwg file, use the File SaveAs Export Layout to modelspace drawing option, close the drawing and repeat for the next Inventor dwg file.
I was looking for the needed method under the document object but there doesn't appear to be anything in the SaveAs or the Export methods to accomodate this.
Thanks for any light that you can shed.
Bob
0 REPLIES 0
”Boost
