.NET
Help Help Connecting VB.net to AutoCAD 2012. It's allmost impossable
25 REPLIES 25
Message 1 of 26
muckmailer
1468 Views, 25 Replies
I have been trying to connect to AutoCAD 2012 64 bit without any luck. for some time.
I have tryed Jerry Winters templates for autoCAD 2010 64 bit. No luck because it can't
find the working directory.  If I try to correct that problem I come up with other errors.
I have trying installing AutoCAD 2012 wizzard and I have no luck to get it working When I install
It says "Visual Studio Express 2008 or 2010 not installed "when I have VS 2008 allready installed on
my machine. Unblocking the file does not change anything.  Is a another dead end.
I have VS 2008 express install on my AutoCAD 2012 machine 64 bit. Can some give
a suggestion to make a VB.net connection to AutoCAD. Maybe a working sample program
works on AutoCAD 2012 (64 bit) would help. Maybe a 2012 template for AutoCAD 2012 (64bit)
to see if a can get some kind of AutoCAD connection.
Any suggestions, I am about to give up on this VB.net thing.
Thank you,
25 REPLIES 25
Message 21 of 26
muckmailer
in reply to: muckmailer
The attached file shows the error I get after following the above proceedure.
Message 22 of 26
muckmailer
Well I got AutoCAD wizzard install on VS 2008 but when I start a AutoCAD template how should I
fill in the box showen in the file attachment.
Thank you,
Message 23 of 26
sometimes my feeling is I'm tested here 😉
If you have the Wizard already downloaded (I checked it now from >>>here<<<, scroll down a bit until you see the link to this zip: AutoCAD 2010-2012 DotNet Wizards.zip).
Within that zip-file you have a directory Installing_and_using_the_AutoCAD_dotNET_Wizards and that has a quite simple and quite detailed description for how to install it and how to use it.
Why don't you look at the tools&helps&docs you already have?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 24 of 26
I have Net Wazard installed on Vb.net 2008 and I have a template but when I run that program
from that template I get errors. I am not at my 64 bit computer until Monday but I will review what
we have done and get back with you. I have an file attach that show resulting errors.
Message 25 of 26
_rhenley
So when exactly do you plan on installing the required development environment for debugging with AutoCAD 2012 ? Or are you just going to continue to beat yourself up by continuing to use Express 2008 instead ?
Message 26 of 26
muckmailer
Well,   would I be better off to use VS 2010 express on it?
Would that solve a lot of setup problems?
I guess I would need to reinstall wizzard after in install VS2012 express on it.
Thank youi,
”Boost
