.NET
Distinguished Contributor
muckmailer
Message 21 of 26 (226 Views)
Re: Help Help Connecting VB.net to AutoCAD 2012. It's allmost impossable
05-03-2012 10:14 AM in reply to: muckmailer
The attached file shows the error I get after following the above proceedure.
muckmailer
Message 22 of 26 (223 Views)
05-03-2012 10:32 AM in reply to: muckmailer
Well I got AutoCAD wizzard install on VS 2008 but when I start a AutoCAD template how should I
fill in the box showen in the file attachment.
Thank you,
Alfred.NESWADBA
Message 23 of 26 (214 Views)
05-03-2012 12:18 PM in reply to: muckmailer
sometimes my feeling is I'm tested here :smileywink:
If you have the Wizard already downloaded (I checked it now from >>>here<<<, scroll down a bit until you see the link to this zip: AutoCAD 2010-2012 DotNet Wizards.zip).
Within that zip-file you have a directory Installing_and_using_the_AutoCAD_dotNET_Wizards and that has a quite simple and quite detailed description for how to install it and how to use it.
Why don't you look at the tools&helps&docs you already have?
- alfred -
Alfred NESWADBA
muckmailer
Message 24 of 26 (202 Views)
05-05-2012 11:12 AM in reply to: Alfred.NESWADBA
I have Net Wazard installed on Vb.net 2008 and I have a template but when I run that program
from that template I get errors. I am not at my 64 bit computer until Monday but I will review what
we have done and get back with you. I have an file attach that show resulting errors.
Valued Contributor
_rhenley
Message 25 of 26 (193 Views)
05-05-2012 12:21 PM in reply to: muckmailer
So when exactly do you plan on installing the required development environment for debugging with AutoCAD 2012 ? Or are you just going to continue to beat yourself up by continuing to use Express 2008 instead ?
muckmailer
Message 26 of 26 (181 Views)
05-06-2012 05:42 AM in reply to: muckmailer
Well,   would I be better off to use VS 2010 express on it?
Would that solve a lot of setup problems?
I guess I would need to reinstall wizzard after in install VS2012 express on it.
Thank youi,
