.NET
Help file installation error
3 REPLIES 3
zzhang2002
512 Views, 3 Replies
Hi! I downloaded ObjectARX 2012 Documentation - VS2010.msi. I ran the installer package. Then I opened VS 2010. Form Help menu, I chose Manage Help Settings. Then on the Help Library Manager dialog box, I chose Install conten from disk. I selected helpcontentsetup.msha. During installation, it popped up an error message.
An exception has occurred. See the event log for details. The help files were not installed. Here is the content of the related event log error entry.
Log Name: Application
Source: HelpLibManager
EventID: 1003
An error occurred while updating local content: Microsoft.Help.CacheLib.CacheLibCabSignatureException: The digital signature on file c:\ProgramData\Microsoft\HelpLibrary\content\Autodesk, Inc\incoming\4fded98b-55d4-4d12-83ea-86498d9c82c0\AdskManaged.cab could not be verified.
at Microsoft.Help.CacheLib.DocumentationCache.<>c__DisplayClass5c.<VerifyAndExtractPackages>b__58(String cabFile)
at Microsoft.Help.CacheLib.Extensions.Each[T](IEnumerable`1 that, Action`1 lambda)
at Microsoft.Help.CacheLib.DocumentationCache.VerifyAndExtractPackages(VendorName vendorName, ChangeDescription change, StatusCallback`1 statusCallback, CertificateCheckCallback certCheckCallback)
at Microsoft.Help.CacheLib.DocumentationCache.IntegrateChange(VendorName vendorName, ChangeDescription change, StatusCallback`1 statusCallback, CertificateCheckCallback certCheckCallback)
at Microsoft.Help.CacheLib.DocumentationCache.Update(VendorName vendorName, Boolean checkForOnlineUpdates, StatusCallback`1 statusCallback, CertificateCheckCallback certCheckCallback)
at Microsoft.Help.CacheLib.CacheManager.<>c__DisplayClass24.<UpdateAsync>b__23()
at Microsoft.Help.CacheLib.AsyncOperationRunner.Run(Object state)
Please help.
Zhuo
3 REPLIES 3
fenton.webb
in reply to: zzhang2002
That looks like we need to resign the cab files, sorry about that
Fenton Webb
AutoCAD Engineering
zzhang2002
Thanks for your reply. Which AutoCAD version of .NET reference help files has no digital signature error?
Balaji_Ram
Are you trying to use the ObjectARX documentation from within Visual Studio as integrated help ?
I dont think that is possible yet.
I use it all the time using the online documentation or the local chm files in the docs folder.
Balaji
Developer Technical Services
Autodesk Developer Network
”Boost
