.NET
HatchLoops and draw borders of hatches
0 REPLIES 0
Message 1 of 1
288 Views, 0 Replies
Hallo all,
i have many hatches with deleted borders. Now i wanted to make a function
which recreates the borders.
It is not possible to get the ObjectIds of the Loops because they are
deleted. I can get the HatchLoop and a Curve2d.
But now i need a Curve-Entity because i need the borders in the drawing.
How can i do this? Is it possible to make it?
I don't need them associative to the new borders, just need the borders.
Here is the code i have till now, just have no idea how to make a Curve2d to
a Curve:
#region Using directives
using System;
using System.Collections.Generic;
using System.Text;
using System.Threading;
using System.Globalization;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.Geometry;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.Runtime;
#endregion
[assembly: CommandClass(typeof(RSNNAcadApp.ExtendedCommands.Testerl))]
namespace RSNNAcadApp.ExtendedCommands
class Testerl
[CommandMethod("HatchLoops")]
public void Test()
Database db = HostApplicationServices.WorkingDatabase;
//Transaction myT = db.TransactionManager.StartTransaction();
Editor ed = Application.DocumentManager.MdiActiveDocument.Editor;
Hatch HatchObj;
PromptEntityOptions HatchOptions = new PromptEntityOptions("Hatch wählen");
PromptEntityResult HatchResult = null;
do
HatchResult = ed.GetEntity(HatchOptions);
} while (HatchResult.Status == PromptStatus.Error);
if (HatchResult.Status == PromptStatus.Cancel)
return;
else if (HatchResult.Status == PromptStatus.OK)
ObjectId entid = HatchResult.ObjectId;
Entity tmpEnt = null;
using (Transaction myT2 = db.TransactionManager.StartTransaction())
tmpEnt = (Entity)myT2.GetObject(entid, OpenMode.ForRead);
//Entity tmpEnt = (Entity)myT.GetObject(entid, OpenMode.ForRead);
HatchObj = tmpEnt as Hatch;
if (HatchObj != null)
ed.WriteMessage(String.Format("\nLoops: {0}",
HatchObj.NumberOfLoops.ToString()));
for (int i = 0; i < HatchObj.NumberOfLoops; i++)
ed.WriteMessage(String.Format("\nObjekt {0} = {1}", i.ToString(),
HatchObj.LoopTypeAt(i).ToString()));
HatchLoop HL = HatchObj.GetLoopAt(i) ;
// Does not work because the borders of the hatch are ereased
ObjectIdCollection IDColl = HatchObj.GetAssociatedObjectIdsAt(i);
Entity tmpEnt2 = null;
using (Transaction myT1 = db.TransactionManager.StartTransaction())
tmpEnt2 = (Entity)myT1.GetObject(IDColl[0], OpenMode.ForRead);
tmpEnt2.GetType().ToString()));
Curve2dCollection CC = HL.Curves;
Curve2d Border = CC[0];
Roland Feletic
Ingenieurbuero A. Pauser Ges.m.b.H.
http://www.pauser.at
hp workstation xw4200, 3GB
quadro fx1400
AutoCAD 2007, 3DSMax 8.0 SP 2
0 REPLIES 0
”Boost
