.NET
Hatch with transparency
4 REPLIES 4
danny.boy.1
770 Views, 4 Replies
Hello
Maybe someone can help me.
Is posible to add on drawing hatch (one color) with
transparency?
I want to fill some entities with transparent color.
I am sending attachment with example (selection rectangle in autocad).
Best regards,
Danijel Ivankovic
4 REPLIES 4
kob4lt
in reply to: danny.boy.1
Sto ti zelis tocno napravit?
Jeffrey_H
in reply to: kob4lt
You can use the entities transparency property
  [CommandMethod("TestTransparencyHatch", CommandFlags.Modal)]
        public void TransparencyHatch()
            Database db = HostApplicationServices.WorkingDatabase;
            using (Transaction tr = db.TransactionManager.StartTransaction())
                BlockTable bt = tr.GetObject(db.BlockTableId, OpenMode.ForRead) as BlockTable;
                BlockTableRecord btr = bt[BlockTableRecord.ModelSpace].GetObject(OpenMode.ForRead) as BlockTableRecord;
                    foreach (ObjectId btrObjId in btr)
                        Entity ent = btrObjId.GetObject(OpenMode.ForRead) as Entity;
                        if (ent is Hatch)
                            ent.UpgradeOpen();
                            Autodesk.AutoCAD.Colors.Transparency trpy = new Autodesk.AutoCAD.Colors.Transparency(40);
                            ent.Transparency = trpy;
                tr.Commit();
You can also find your answers @ TheSwamp
Jeffrey_H
in reply to: Jeffrey_H
danny.boy.1
in reply to: kob4lt
Pozdrav!
Lijepo je vidjeti da postoji na ovom forumu neko i sa "naših" prostora :-)!
Htio sam dodati na model terena koji se sastoji od SubDMesh objekta
transparentnost.
Ta mogućnost postoji tek od verzije AutoCAD 2011.
”Boost
