.NET
Active Member
everts
Message 1 of 3 (182 Views)
Hatch pattern scale problem
182 Views, 2 Replies
08-30-2007 08:11 AM
The following is a part of my code that draw a Polyline with a hatch style, but, I am having some troubles with the pattern scale value. In the code, I put 5 in the pattern scale, but, when I see the properties in LandDesktop, I see the value I wrote (5), but the hatch appears to have another value instead, I mean, if I write manually the value (5), the hatch's appearance change radically. My apologies for my bad english. Thanks in advance!
myHatch.SetHatchPattern(HatchPatternType.PreDefined, "AR-SAND");
myHatch.ColorIndex = 2;
myHatch.PatternScale = 5;
ghethco
Message 2 of 3 (105 Views)
Re: Hatch pattern scale problem
07-17-2012 06:02 AM in reply to: everts
I am seeing the same problem. Anyone know why? Gary
ADN Support Specialist
Virupaksha.aithal
Message 3 of 3 (91 Views)
07-30-2012 02:05 AM in reply to: ghethco
Hi
Try setting “SetHatchPattern” after setting “PatternScale” like
Virupaksha Aithal KM
Developer Technical Services
Autodesk Developer Network
