.NET
HandleToObject
6 REPLIES 6
v_shanmugasundaram
583 Views, 6 Replies
HandleToObject
Hello All,
can any body knows , how to use HandleToObject method in .Net API ?
Thanks in advance.
6 REPLIES 6
in reply to: v_shanmugasundaram
I'm not sure what you mean. Do you want to use this COM API from a .NET
language or are you looking fore a similar/equivalent method in the .NET
API?
Albert
wrote in message
news:4955666@discussion.autodesk.com...
Hello All,
Thanks in advance.
i am looking for similar/equivalent method of HandletoObject in the .NET API?
Database.GetObjectId()
wrote in message
news:4959993@discussion.autodesk.com...
API?
HI Albert:
from help file, GetObjectId required a Autodesk.AutoCAD.DatabaseServices.Handle object as parameter. How I can create a Handle object from a string? Do you have any sample code?
Thank you
Wes
Windows 10 64 bit, AutoCAD (ACA, Map) 2023
Handle HandleFromString(string hexstr)
return new Handle(Int64.Parse(hexstr, NumberStyles.HexNumber));
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2004/2005/2006
http://www.acadxtabs.com
wrote in message news:4970859@discussion.autodesk.com...
HI Albert:
Thank you
Wes
thank you
”Boost
