.NET
Handle.isNull
2 REPLIES 2
wesbird
173 Views, 2 Replies
Handle.isNull
I just found the Handle.isNull does not exposed in .NET. then how I can check if a handle == null?
Handle.ToString() == ""
or
Handle.ToString() == "0"
which one is correct ?
Thank you,
Wes
Windows 10 64 bit, AutoCAD (ACA, Map) 2023
2 REPLIES 2
in reply to: wesbird
Handle.Value == 0
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2004/2005/2006/2007
http://www.acadxtabs.com
wrote in message news:5311236@discussion.autodesk.com...
or
Thank you,
Wes
wesbird
Thank you, I will try it.
”Boost
