.NET
Distinguished Contributor
quigs
Message 1 of 6 (312 Views)
Grid stops overrule from working
312 Views, 5 Replies
11-10-2012 02:55 AM
Hi there,
I have created a polyline overrule with custom gips and worlddraw
and we have an odd occurrence.  On 3 of our test machines it works fine.
But on my machine (the best and newest one), if I have the grid turned
on the overrule wont display.  Its invisible.  If you do a select all you can
see it but you can’t select it.
I thought maybe it was a custom grip issue but then why when the grid is
Off does it work fine?  What worries me a little is that to figure this out
was purely luck.  I can put in a call to turn the grid off but this isn’t finding the
problem.
Any clues?
Thanks in advance :smileyvery-happy:.
My name is Martin.. :smileyvery-happy:
Thank you for that,
we found that we didn't put in a tr.Commit(); in the worlddraw.  Now it's back in it works perfectly.
:smileyvery-happy: :smileyvery-happy: :smileyvery-happy::smileyvery-happy::smileyvery-happy::smileyvery-happy::smileyvery-happy:
quigs
Message 2 of 6 (264 Views)
Re: Grid stops overrule from working
11-12-2012 01:14 AM in reply to: quigs
We just tested this on some other machines and the GRID is defiantly stopping it working when activated.
Very weird.
quigs
Message 3 of 6 (239 Views)
11-13-2012 09:55 AM in reply to: quigs
BUMP!
No takers,
not even the mods?
ADN Support Specialist
Balaji_Ram
Message 4 of 6 (191 Views)
11-20-2012 03:14 AM in reply to: quigs
Hello Martin,
I tried a sample code that overrules polyline and then turned GRID on/off but the overrule did work correctly in both cases. Here is a very simple drawable overrule code that I am using to draw circles at each vertex of the overruled pline. I have tried it with AutoCAD 2011 and 2013 and it worked ok. Which version are you using ?
Is it system specific ? If so, have you tried resetting the AutoCAD settings by using the "Reset Settings to Default" ?
Here is the sample code. You can draw a pline and then run the Test command to select the pline.
    public class MyDrawOverrule : DrawableOverrule
        public override bool WorldDraw(Drawable drawable, WorldDraw wd)
            Autodesk.AutoCAD.DatabaseServices.Polyline pline = drawable as Autodesk.AutoCAD.DatabaseServices.Polyline;
            if (pline != null)
                short clr = 1;
                int segCount = pline.NumberOfVertices;
                for (int cnt = 0; cnt < segCount; cnt++)
                    Point3d vertexPt = pline.GetPoint3dAt(cnt);
                    SegmentType type = pline.GetSegmentType(cnt);
                    switch (type)
                        case SegmentType.Arc:
                            CircularArc2d arc2d = pline.GetArcSegment2dAt(cnt);
                            clr = wd.SubEntityTraits.Color;
                            wd.SubEntityTraits.Color = 2;
                            wd.Geometry.Circle(vertexPt, arc2d.GetLength(arc2d.GetParameterOf(arc2d.StartPoint), arc2d.GetParameterOf(arc2d.EndPoint)) * 0.2, pline.Normal);
                            wd.SubEntityTraits.Color = clr;
                            break;
                        case SegmentType.Line:
                            LineSegment2d line2d = pline.GetLineSegment2dAt(cnt);
                            wd.Geometry.Circle(vertexPt, line2d.GetLength(line2d.GetParameterOf(line2d.StartPoint), line2d.GetParameterOf(line2d.EndPoint)) * 0.2, pline.Normal);
                            break;
                        case SegmentType.Coincident:
                            break;
                        case SegmentType.Empty:
                            break;
                        case SegmentType.Point:
                            break;
            return base.WorldDraw(drawable, wd);
    public class Commands
        static MyDrawOverrule pldo = null;
        static List<ObjectId> plineIds = new List<ObjectId>();
        [CommandMethod("Test")]
        public void TestMethod()
            Document doc = Application.DocumentManager.MdiActiveDocument;
            Editor ed = doc.Editor;
            PromptEntityResult per = ed.GetEntity("\nSelect a polyline");
            if (per.Status != PromptStatus.OK)
                return;
            plineIds.Add(per.ObjectId);
            if (pldo == null)
                pldo = new MyDrawOverrule();
                Overrule.AddOverrule(RXObject.GetClass(typeof(Autodesk.AutoCAD.DatabaseServices.Polyline)), pldo, true);
                pldo.SetIdFilter(plineIds.ToArray());
                Overrule.Overruling = true;
            else
            using (Transaction tr = doc.Database.TransactionManager.StartTransaction())
                Entity reg = (Entity)tr.GetObject(per.ObjectId, OpenMode.ForWrite);
                reg.RecordGraphicsModified(true);
                tr.TransactionManager.QueueForGraphicsFlush();
                tr.Commit();
Balaji
Developer Technical Services
Autodesk Developer Network
quigs
Message 5 of 6 (181 Views)
11-20-2012 07:52 AM in reply to: Balaji_Ram
Thanks for the reply,
It isn't machine specific because we have just tested, and the bug seems to appear on both of our machines.  We are re-writing now and adding back in some custom grips.  We believe it may be a problem there.  I will post here when I know more.
Maritn.
quigs
Message 6 of 6 (165 Views)
11-21-2012 03:16 AM in reply to: quigs
Thank you for that,
