.NET
Grabbing pt coordinates from an external file then creating lines from them
2 REPLIES 2
480 Views, 2 Replies
Wondering if someone might know why I keep getting crashes --
is it something in my code? Or something else?
The code I have in the attachment crashes with an error:
"FATAL ERROR: Unhandled e0434f4dh Exception at 7c812a6bh"
(curious if someone knows a way to force the system to give a meaningful error message?)
How I wish it would give a more meaningful error message
Anyhow my screen is shown in the file "Screenshot Of My Error Message I am seeing and Exact Line of Code Where It Is Coming From.jpg"
from the attachment file "Need Help Crashing.zip"
All I want to do is grab coordinates from a file called csv.csv ... dynamically create points using those coordinates and connect created points with lines.
My code is shown below and also attached to this thread.
'* cmdImport IS A COMMAND BUTTON FROM A FORM *
Private Sub cmdImport_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles cmdImport.Click
Dim tsr As System.IO.StreamReader
Dim oarrData As Object, intCount As Integer = 0
Dim clsK As New clsKx
Dim oarrData1 As New Object
ofdSelectCSV.ShowDialog()
tsr = System.IO.File.OpenText(ofdSelectCSV.FileName)
While (tsr.Peek <> -1)
oarrData = Split(tsr.ReadLine, ",")
If intCount = 0 Then
oarrData1 = Split(tsr.ReadLine, ",")
Else
Dim pt2 As New Point3d(CDbl(oarrData(1)), CDbl(oarrData(2)), CDbl(oarrData(3)))
Dim pt1 As New Point3d(CDbl(oarrData1(1)), CDbl(oarrData1(2)), CDbl(oarrData1(3)))
clsK.CreateLineOnALayer(pt1, pt2, "0")
pt1 = pt2
End If
intCount += 1
End While
End Sub
'* SUBROUTINES BELOW ARE IN CLSK CLASS *
Public Sub CreateLineOnALayer(ByVal pt1 As Point3d, ByVal pt2 As Point3d, ByVal strNameOfLayer As String)
CreateAlayer(strNameOfLayer)
Dim doc As Document = Application.DocumentManager.MdiActiveDocument
Dim db As Database = doc.Database
Dim trans As Transaction
Dim transMan As Autodesk.AutoCAD.ApplicationServices.TransactionManager
transMan = db.TransactionManager
trans = transMan.StartTransaction
Dim lne As New Line(pt1, pt2)
Dim bt As BlockTable
Dim btr As BlockTableRecord
bt = trans.GetObject(db.BlockTableId, OpenMode.ForRead)
btr = trans.GetObject(bt(BlockTableRecord.ModelSpace), OpenMode.ForWrite)
lne.Layer = strNameOfLayer
btr.AppendEntity(lne)
trans.AddNewlyCreatedDBObject(lne, True)
trans.Commit()
trans.Dispose()
transMan.Dispose()
End Sub
Public Sub CreateAlayer(ByVal strName As String)
Dim lyrT As LayerTable
lyrT = trans.GetObject(db.LayerTableId, OpenMode.ForRead)
If lyrT.Has(strName) = False Then
lyrT.UpgradeOpen()
Dim lyrTr As New LayerTableRecord
lyrTr.Name = strName
lyrT.Add(lyrTr)
trans.AddNewlyCreatedDBObject(lyrTr, True)
trans.Commit()
End If
trans.Dispose()
transMan.Dispose()
End Sub
2 REPLIES 2
Your code calls Form.Show() to show your form
modelessly.
In a modeless form, you've got to lock the document
before you can modify it.
Search this newsgroup for 'eLockViolation' for
more on locking the document.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD
Supporting AutoCAD 2000 through 2011
http://www.acadxtabs.com
Email: string.Format("{0}@{1}.com", "tonyt", "caddzone");
wrote in message news:6399965@discussion.autodesk.com...
message?)
Else
CDbl(oarrData(3)))
CDbl(oarrData1(3)))
pt1 = pt2
End If
intCount += 1
End While
End Sub
OpenMode.ForWrite)
trans.Commit()
trans.Dispose()
transMan.Dispose()
End Sub
lyrT.UpgradeOpen()
lyrT.Add(lyrTr)
trans.Commit()
End If
trans.Dispose()
transMan.Dispose()
End Sub
Nothing has made me happier for the past several days now than to see my code
working, perfectly -- I feel fantastic --- thank you so much Tony locking the document
like you suggested has freed me from so many miserble hours hitting walls
... cheers and have a great weekend.
Gratefully,
Matt
”Boost
