.NET
Grabbing pt coordinates from an external file then creating lines from them
2 REPLIES 2
matt_1ca
475 Views, 2 Replies
Wondering if someone might know why I keep getting crashes --
is it something in my code? Or something else?
The code I have in the attachment crashes with an error:
"FATAL ERROR: Unhandled e0434f4dh Exception at 7c812a6bh"
(curious if someone knows a way to force the system to give a meaningful error message?)
How I wish it would give a more meaningful error message
Anyhow my screen is shown in the file "Screenshot Of My Error Message I am seeing and Exact Line of Code Where It Is Coming From.jpg"
from the attachment file "Need Help Crashing.zip"
All I want to do is grab coordinates from a file called csv.csv ... dynamically create points using those coordinates and connect created points with lines.
My code is shown below and also attached to this thread.
'* cmdImport IS A COMMAND BUTTON FROM A FORM *
Private Sub cmdImport_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles cmdImport.Click
Dim tsr As System.IO.StreamReader
Dim oarrData As Object, intCount As Integer = 0
Dim clsK As New clsKx
Dim oarrData1 As New Object
ofdSelectCSV.ShowDialog()
tsr = System.IO.File.OpenText(ofdSelectCSV.FileName)
While (tsr.Peek <> -1)
oarrData = Split(tsr.ReadLine, ",")
If intCount = 0 Then
oarrData1 = Split(tsr.ReadLine, ",")
Else
Dim pt2 As New Point3d(CDbl(oarrData(1)), CDbl(oarrData(2)), CDbl(oarrData(3)))
Dim pt1 As New Point3d(CDbl(oarrData1(1)), CDbl(oarrData1(2)), CDbl(oarrData1(3)))
clsK.CreateLineOnALayer(pt1, pt2, "0")
pt1 = pt2
End If
intCount += 1
End While
End Sub
'* SUBROUTINES BELOW ARE IN CLSK CLASS *
Public Sub CreateLineOnALayer(ByVal pt1 As Point3d, ByVal pt2 As Point3d, ByVal strNameOfLayer As String)
CreateAlayer(strNameOfLayer)
Dim doc As Document = Application.DocumentManager.MdiActiveDocument
Dim db As Database = doc.Database
Dim trans As Transaction
Dim transMan As Autodesk.AutoCAD.ApplicationServices.TransactionManager
transMan = db.TransactionManager
trans = transMan.StartTransaction
Dim lne As New Line(pt1, pt2)
Dim bt As BlockTable
Dim btr As BlockTableRecord
bt = trans.GetObject(db.BlockTableId, OpenMode.ForRead)
btr = trans.GetObject(bt(BlockTableRecord.ModelSpace), OpenMode.ForWrite)
lne.Layer = strNameOfLayer
btr.AppendEntity(lne)
trans.AddNewlyCreatedDBObject(lne, True)
trans.Commit()
trans.Dispose()
transMan.Dispose()
End Sub
Public Sub CreateAlayer(ByVal strName As String)
Dim lyrT As LayerTable
lyrT = trans.GetObject(db.LayerTableId, OpenMode.ForRead)
If lyrT.Has(strName) = False Then
lyrT.UpgradeOpen()
Dim lyrTr As New LayerTableRecord
lyrTr.Name = strName
lyrT.Add(lyrTr)
trans.AddNewlyCreatedDBObject(lyrTr, True)
trans.Commit()
End If
trans.Dispose()
transMan.Dispose()
End Sub
2 REPLIES 2
in reply to: matt_1ca
Your code calls Form.Show() to show your form
modelessly.
In a modeless form, you've got to lock the document
before you can modify it.
Search this newsgroup for 'eLockViolation' for
more on locking the document.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD
Supporting AutoCAD 2000 through 2011
http://www.acadxtabs.com
Email: string.Format("{0}@{1}.com", "tonyt", "caddzone");
wrote in message news:6399965@discussion.autodesk.com...
message?)
Else
CDbl(oarrData(3)))
CDbl(oarrData1(3)))
pt1 = pt2
End If
intCount += 1
End While
End Sub
OpenMode.ForWrite)
trans.Commit()
trans.Dispose()
transMan.Dispose()
End Sub
lyrT.UpgradeOpen()
lyrT.Add(lyrTr)
trans.Commit()
End If
trans.Dispose()
transMan.Dispose()
End Sub
matt_1ca
Nothing has made me happier for the past several days now than to see my code
working, perfectly -- I feel fantastic --- thank you so much Tony locking the document
like you suggested has freed me from so many miserble hours hitting walls
... cheers and have a great weekend.
Gratefully,
Matt
”Boost
