.NET
wang890
Message 1 of 10 (444 Views)
given coordinate, find polyline width at that segment
444 Views, 9 Replies
01-14-2013 11:11 AM
i have a set of coordinates, not on the polyline. i want to find the polyline width where that coodinate intersects perpendicular to the polyline (shortest distance). without going through all the vertices.
i have a polyline with many segments with varying width, which are constant through the each segments (no taper width). need to read off the "instantaneous" width.
just 2dpoly or lwpoly not 3d.
i found this
http://through-the-interface.typepad.com/through_the_interface/2012/01/testing-whether-a-point-is-on...
not quite what i want.
thanks
Civil 3D 2012
Work: Xeon W3503, 12GB, Quadro 2000, Yamakasi Sparta 301 + Dell PH2211
Home: 3930k, 12GB, GTX 590, U3011, QX2710
wang890 wrote:
the getparameteratpoint returns a double? what is it which parameter does it return?
For Polyline parameter is number of vertex. For example parameter == 1 means second vertex, parameter = 2.5 means  middle between third and fourth vertex.
What are AcDbCurve/Curve Parameters? ObjectARX/.NET
Getting the Midpoint of each Polyline Segment using ObjectARX
wang890
Message 2 of 10 (438 Views)
Re: given coordinate, find polyline width at that segment
01-14-2013 11:56 AM in reply to: wang890
i thought about going through the polyline vertices one at a time and then take my point and calculate distance. find the shortest distance from that and then record the index where that happens.
but i am afraid it may slow down my program. i have 1000 of these to run and if it goes through 1000 vertices could be slow. but i am gonna try it with my way first and hopefully someone has a better way.
Civil 3D 2012
Jeff_M
Message 3 of 10 (417 Views)
01-14-2013 05:51 PM in reply to: wang890
A polyline derives froma Curve, so it inherits the GetClosestPointTo() method. With the point you can get the parameter at the point which you can then use to GetStartWidthAt()
wang890
Message 4 of 10 (399 Views)
01-15-2013 09:02 AM in reply to: Jeff_M
thanks jeff very helpful. not figured out yet but getting there.
where is the help file for all these rare functions? i think there is none. like roughly explains what the arguments you need to feed it do.
not just for this but generally for everything.
Civil 3D 2012
wang890
Message 5 of 10 (396 Views)
01-15-2013 09:25 AM in reply to: wang890
how do you get closest index giving a point?
doesn't have a "GetIndexAt" function
i need to get the index without going through the vertices as this will slow down my subassembly.
Civil 3D 2012
Moderator
Alexander.Rivilis
Message 6 of 10 (392 Views)
01-15-2013 09:54 AM in reply to: wang890
Пожалуйста не забывайте про Утвердить в качестве решения! Утвердить в качестве решения и Give Kudos!Баллы
Please remember to Accept Solution! Accept as Solution and Give Kudos!Kudos
wang890
Message 7 of 10 (388 Views)
01-15-2013 10:09 AM in reply to: Alexander.Rivilis
seen.
i am off testing this now.
2.6 of a vertex lol.
Civil 3D 2012
wang890
Message 8 of 10 (375 Views)
01-15-2013 05:05 PM in reply to: wang890
works, here's the code
Dim oEmbankmentTypeTarget As WidthOffsetTarget
            Try
                oEmbankmentTypeTarget = oParamsOffsetTarget.Value("TargetHA1")
                Dim acDoc As Document = Application.DocumentManager.MdiActiveDocument
                Dim acCurDb As Database = acDoc.Database
                Using lock As DocumentLock = acDoc.LockDocument
                    Using acTrans As Transaction = acCurDb.TransactionManager.StartTransaction()
                        '' Open the Block table for read
                        Dim acBlkTbl As BlockTable
                        acBlkTbl = acTrans.GetObject(acCurDb.BlockTableId, OpenMode.ForRead)
                        '' Open the Block table record Model space for write
                        Dim acBlkTblRec As BlockTableRecord
                        acBlkTblRec = CType(acTrans.GetObject(acBlkTbl(BlockTableRecord.ModelSpace), _
                                                        OpenMode.ForWrite), BlockTableRecord)
                        Dim obj As DBObject = acTrans.GetObject(oEmbankmentTypeTarget.TargetId, OpenMode.ForWrite)
                        If TypeOf obj Is Polyline Then
                            Dim oPoly2dOrig As Polyline = CType(obj, Polyline)
                            'get the index where the current station is closest to
                            Dim x, y, z As Double
                            corridorState.SoeToXyz(corridorState.CurrentAlignmentId, corridorState.CurrentStation, 0, 0, x, y, z)
                            Dim oPt3D_CL As New Point3d(x, y, z)
                            'get vertex index (fraction)
                            Dim dVertex As Double = oPoly2dOrig.GetParameterAtPoint(oPoly2dOrig.GetClosestPointTo(oPt3D_CL, True))
                            'get polyline width
                            dSegmentWidth = oPoly2dOrig.GetStartWidthAt(Truncate(dVertex))
                        End If
                    End Using
                End Using
Civil 3D 2012
Moderator
Alexander.Rivilis
Message 9 of 10 (365 Views)
01-15-2013 10:18 PM in reply to: wang890
IMHO method Truncate should be replaced with method Round.
wang890
Message 10 of 10 (360 Views)
01-15-2013 10:56 PM in reply to: wang890
no, have to round down.
say point 0 to 10 is 0.5m wide, 10-20 is 1.0m wide. when hit 9.99 say it is still within the 0.5m geotechnical zone.
don't worry i am all good.
cheers mate.
Civil 3D 2012
