.NET
Getting Z with getpoint
3 REPLIES 3
295 Views, 3 Replies
I'm trying to get a point. The problem is that if the user goes to View->3d Views->Front, it will show the front but it still shows it as if it's on the XY plane instead of the XZ plane. When the user selects a point on the screen it shows up as xxx,xxx,0. When I did a similar thing in VBA and user selected a point, it would show up as xxx,0,xxx. Is there some way I can get it to detect what view its in so that I can get the Z coordinate or is there a better way to accomplish the same thing?
3 REPLIES 3
What UCS is active in the view the user picks the point in?
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD
Supporting AutoCAD 2000 through 2010
http://www.acadxtabs.com
Email: string.Format("{0}@{1}.com", "tonyt", "caddzone");
wrote in message news:6300426@discussion.autodesk.com...
Ah, I see. I didn't realized that the .NET version of getpoint gets it in UCS. I assumed that it worked the same as VBA. Once I convert, it works fine, but do I have to convert or is there some way I can get it in WCS?
No, you have to convert it.
wrote in message news:6300648@discussion.autodesk.com...
”Boost
