.NET
Predator_mpm
Message 1 of 2 (269 Views)
Getting viewport UCS
269 Views, 1 Replies
09-03-2013 06:22 AM
I hope if you can help me with this problem, I am still stuck at it. My objective is to find whether a layout viewport has a rotated ICS or not.
I have attached a visual studio 2012 project along a testdrawing, please check my code and tell me why it is not working.
In fact the code works but not always, for example if you run the code and select the viewport in the layout of the attached drawing, it will falsely give you (1,0,0) which is the vector or the world ucs x-axis, but this is not true. Now activate the model space in the viewport in autocad manually, then run the code again, it would work and give you the right coordinates of the ucs x-axis.
I don't understand how and why it works this way, so could you help me a little please.
I think the real problem is in the part of the code that makes the viewport active, I cannot believe that there is no code in vb.net to activate a viewport, and using the com code may be the problem.
Great thanks for you, I hope this problem gets resolved.
Public Class Test
    <CommandMethod("GetUCS", CommandFlags.NoTileMode)> _
    Public Sub GetUCS()
        Dim acDoc As Document = Application.DocumentManager.MdiActiveDocument
        Dim acCurdb As Database = acDoc.Database
        Dim ed As Editor = acDoc.Editor()
        Dim peo As New PromptEntityOptions("Select a viewport : ")
        peo.SetRejectMessage("Select a viewport.")
        peo.AddAllowedClass(GetType(Autodesk.AutoCAD.DatabaseServices.Viewport), True)
        Dim per As PromptEntityResult = ed.GetEntity(peo)
        Dim vpId As ObjectId = per.ObjectId
        Dim acadDoc As AcadDocument = Autodesk.AutoCAD.ApplicationServices.DocumentExtension.GetAcadDocument(acDoc)
        ed.SwitchToModelSpace()
        Using tr As Transaction = acCurdb.TransactionManager.StartTransaction()
            Dim vp As Autodesk.AutoCAD.DatabaseServices.Viewport = TryCast(tr.GetObject(vpId, OpenMode.ForRead), Autodesk.AutoCAD.DatabaseServices.Viewport)
            'Setting the chosen viewport active
            acadDoc.ActivePViewport = vp.AcadObject
            'I just want to read the x-axis vector to know whether the viewport has been rotated or not
            Dim curXdir As Vector3d = acCurdb.Ucsxdir
            ed.WriteMessage(vbLf & curXdir.ToString)
            tr.Commit()
        End Using
        ed.SwitchToPaperSpace()
    End Sub
End Class
ADN Support Specialist
philippe.leefsma
Message 2 of 2 (221 Views)
Re: Getting viewport UCS
09-11-2013 01:46 AM in reply to: Predator_mpm
Hi
Here is some C# code that set a viewport UCS, I would assume the same code works as well to retrieve the current UCS:
[CommandMethod("SetViewportUcs")]
public void SetViewportUcs()
    Document doc = Application.DocumentManager.MdiActiveDocument;
    Editor ed = Application.DocumentManager.MdiActiveDocument.Editor;
    AcadPViewport acadViewport = null;
    AcadDocument acadDoc = doc.GetAcadDocument() as AcadDocument;
    acadDoc.ActiveLayout = acadDoc.Layouts.Item("Layout1");
    //Reference the ViewPort object on Layout (the ActiveLayout)
    if (acadDoc.PaperSpace.Item(1).ObjectName == "AcDbViewport")
        acadViewport = acadDoc.PaperSpace.Item(1) as AcadPViewport;
    //Make sure the Viewport is displayed and on
    acadViewport.Display(true);
    acadViewport.ViewportOn = true;
    //Before making a pViewport active the mspace property needs
    //to be True for a floating viewport
    acadDoc.MSpace = true;
    acadDoc.ActivePViewport = acadViewport;
    acadDoc.Regen(AcRegenType.acActiveViewport);
    Matrix3d newUcsMat = Matrix3d.AlignCoordinateSystem(
        new Point3d(0, 0, 0), new Vector3d(1, 0, 0), new Vector3d(0, 1, 0), new Vector3d(0, 0, 1),
        new Point3d(0, 0, 0), new Vector3d(0, 1, 0), new Vector3d(-1, 0, 0), new Vector3d(0, 0, 1));
    ed.CurrentUserCoordinateSystem = newUcsMat;
Philippe.
Philippe Leefsma
Developer Technical Services
Autodesk Developer Network
Post to the Community
New Post
Announcements
Do you have 60 seconds to spare? The Autodesk Community Team is revamping our site ranking system and we want your feedback! Please click here to launch the 5 question survey. As always your input is greatly appreciated.
