.NET
Valued Contributor
RamanSBV
Message 1 of 3 (164 Views)
Getting the Attach Images file details
164 Views, 2 Replies
08-27-2012 03:12 AM
Please guide me
For retrieving information about attach DWG file there is a API call "db.GetHostDwgXrefGraph(true)"
Similarly is there any API call for Attach Image files
Raman
Here is a code I've found in my code library,
change it to your needs:
 [CommandMethod("ImageName")]
public void GetImageFileName()
Document doc=Application.DocumentManager.MdiActiveDocument;
Database db = doc.Database;
Editor ed= doc.Editor;
ErrorStatus es = new ErrorStatus();
try
using (Transaction tr = db.TransactionManager.StartTransaction())
ObjectId imageDictId = RasterImageDef.GetImageDictionary(db);
DBDictionary imageDict = tr.GetObject(imageDictId, OpenMode.ForRead) as DBDictionary;
ObjectId rasterId = ed.GetEntity("\nSelect an image: ").ObjectId;
RasterImage image = tr.GetObject(rasterId, OpenMode.ForRead) as RasterImage;
ObjectId imageDefId = imageDict.GetAt(image.Name);
RasterImageDef imageDef = tr.GetObject(imageDefId, OpenMode.ForWrite) as RasterImageDef;
string filename = imageDef.ActiveFileName;
Application.ShowAlertDialog(filename);
tr.Commit();
catch (Autodesk.AutoCAD.Runtime.Exception ex)
Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor.WriteMessage
(ex.Message + "\n" + ex.StackTrace);
finally
ed.WriteMessage("\n{0}", es.ToString());
~'J'~
ADN Support Specialist
philippe.leefsma
Message 2 of 3 (143 Views)
Re: Getting the Attach Images file details
08-28-2012 01:33 AM in reply to: RamanSBV
Hi There,
You can use the static API "RasterImageDef.GetImageDictionary".
This will return the id of the RasterImage dictionary. Iterating through its record will give you access to the "RasterImageDef" objects.
Philippe.
Philippe Leefsma
Developer Technical Services
Autodesk Developer Network
Hallex
Message 3 of 3 (137 Views)
08-28-2012 04:58 AM in reply to: RamanSBV
              try
                        tr.Commit();
            finally
~'J'~
