.NET
Getting Saving Settings.
8 REPLIES 8
Message 1 of 9
800 Views, 8 Replies
Hi there,
@The moment i am trying to get the saveAs settings that were used when the user hits the save/saveAs button in autocad.
My addin needs to store the current document with these settings. i dont want to use some pop-up dialog.
The .currentVersion property saves the document with the applicationversions standard saveprofile.
I need some kind of property that reflects the users saveAs settings.
Is there any way getting those information via the .net api without doing the interop stuff?
thank you
8 REPLIES 8
Message 2 of 9
Alexander.Rivilis
If you mean the current format for save, then, for example:
[CommandMethod("DefForSave")]
public static void DefForSave()
  Document doc = Application.DocumentManager.MdiActiveDocument;
  Editor ed = doc.Editor;
  object acadObject = Application.AcadApplication;
  object preferences  = acadObject.GetType().InvokeMember("Preferences",
    BindingFlags.GetProperty, null, acadObject, null);
  object prefOpenSave = preferences.GetType().InvokeMember("OpenSave",
    BindingFlags.GetProperty, null, preferences, null);
  object dwgversion = prefOpenSave.GetType().InvokeMember("SaveAsType",
    BindingFlags.GetProperty, null, prefOpenSave, null);
  ed.WriteMessage("\nDefault Format For Save= {0}", dwgversion);
Facebook | Twitter | LinkedIn
Expert Elite Member
Message 3 of 9
in reply to: Alexander.Rivilis
Thank you very much for your quick answer Alexander,
i am getting an integer value.
unfortuntley i cannot just use this value within the saveAs method of my document.
i get the following values
DWG2010: 48
DWG2007: 36
DWG2000: 12
is there any mapping-Table ? do i have to map it myself?
Message 4 of 9
Alexander.Rivilis
DWG2010: 48
DWG2007: 36
DWG2000: 12
But you can use this value with AcadDocument.SaveAs method:
object adoc = doc.AcadDocument;
object [] parms = new object[2];
parms[0] = doc.Name; parms[1] = dwgversion;
adoc.GetType().InvokeMember("SaveAs", BindingFlags.InvokeMethod, null, adoc, parms);
Expert Elite Member
Message 5 of 9
Good morning Alexander.
Your suggestions where just perfect. Exactly what i was looking for. Thank you very much.
Is there any documentation about the invokemembers and its parameters for ACAD2012/13?
For the rest of this thread it can be closed. 5-Stars-Rating. 😄
Message 6 of 9
Alexander.Rivilis
InvokeMember is a method of type System.Type (part of Reflection)
AcadDocument, AcadPreferences, etc. are classes from AutoCAD ActiveX API
Expert Elite Member
Message 7 of 9
I realize this is an old post, but does this not work for 2016?  I keep getting this error:
     Method 'Autodesk.AutoCAD.ApplicationServices.Document.Saveas' not found.
I may have something wrong in my code, here's what I'm using:
                Autodesk.AutoCAD.ApplicationServices.Document doc2 = Application.DocumentManager.MdiActiveDocument;
                //Get preferences set in AutoCAD for saveas file version.
                    parms[0] = DWGSaveName;
                    DwgVersion ver = (DwgVersion)dwgversion;
                    object adoc = doc2;
                    //acDB.SaveAs(DWGSaveName, true, (DwgVersion)ver, acDB.SecurityParameters);
                    adoc.GetType().InvokeMember("Saveas", BindingFlags.InvokeMethod, null, adoc, parms);
                    returnMsg = "Success";
 What am I doing wrong?
Message 8 of 9
Try replace line of code:
object adoc = doc2;
with
object adoc = doc2.GetAcadDocument();
Expert Elite Member
Message 9 of 9
Bingo!  Thanks a million!
”Boost
