.NET
Getting Method 'get_Item' in type 'Autodesk...' from assebly 'Acdbmgd..' error
1 REPLY 1
NLeininger
306 Views, 1 Reply
My question is it possible to run these assemblies outside of AutoCad completely, or do they need to run inside an instance of AutoCad to work correctly?
For example, I'm trying to write some applications such that I want to read a Autocad drawing, but don't want to be forced into having to use a seat licenese to run my program.
using (Autodesk.AutoCAD.DatabaseServices.Database acDb = new Autodesk.AutoCAD.DatabaseServices.Database(false, false))
                        acDb.ReadDwgFile(fileToProcess, FileShare.ReadWrite, false, string.Empty);
acdb is still an empty object when run outside of AutoCad, however when I run similar code inside AutoCad the database is configured correctly.
1 REPLY 1
dgorsman
in reply to: NLeininger
You can't read DWG files sans AutoCAD without some extra help, such as purchasing a RealDWG license.
If you are going to fly by the seat of your pants, expect friction burns.
"I don't know" is the beginning of knowledge, not the end.
”Boost
