.NET
Active Contributor
aliensinearth
Message 1 of 13 (297 Views)
Getting Fatal Error in Explode method
297 Views, 12 Replies
11-24-2013 10:48 PM
Hello Gentlemen,
I am getting Fatal error at the explode method in the following highlighed (red) code.
Can you please help me?
public class ExplodeDynamicBlocks
        [CommandMethod("EDB")]
        public static void ExplodeDymanicBlockReference()
            Document doc = Application.DocumentManager.MdiActiveDocument;
            Database db = doc.Database;
            Editor ed = doc.Editor;
            using (Transaction tr = db.TransactionManager.StartTransaction())
                BlockTable bt = tr.GetObject(db.BlockTableId, OpenMode.ForRead) as BlockTable;
                BlockTableRecord btr = tr.GetObject(bt["JDuct-SP"], OpenMode.ForWrite) as BlockTableRecord;
                ObjectIdCollection oidc1 = btr.GetAnonymousBlockIds();
                ObjectIdCollection oidc2 = btr.GetBlockReferenceIds(true, false);
                DBObjectCollection dboc = new DBObjectCollection();
                foreach (ObjectId id in oidc1)
                    BlockReference br = tr.GetObject(id, OpenMode.ForWrite) as BlockReference;
                    br.ExplodeToOwnerSpace();   // I am getting Fatal Error at this point
Also, if possible, how to combine two objectidcollection into one?
well, got it to run (and learned something :smileywink: ):
When you look to that object:
AutoCAD returns a BlockTableRecord, not a BlockReference!
So I tried then to get the Blockreferences for that BlockTableRecord and exploded them ... and that worked:
   For Each id As ObjectId In oidc1
      Dim btr2 As BlockTableRecord = TryCast(tr.GetObject(id, OpenMode.ForWrite), BlockTableRecord)
      For Each id2 As ObjectId In btr2.GetBlockReferenceIds(True, False)
         Dim br2 As BlockReference = TryCast(tr.GetObject(id2, OpenMode.ForWrite), BlockReference)
         br2.ExplodeToOwnerSpace()
      Next
   Next
(no cast checking, no error handling, no disposes, just shows the workflow!)
HTH, - alfred -
Alfred.NESWADBA
Message 2 of 13 (289 Views)
Re: Getting Fatal Error in Explode method
11-24-2013 11:58 PM in reply to: aliensinearth
Two questions:
  • have you verified what the owner for the blockreference is (in case of crashing)?
  • have you tried to do br.Explode instead of br.ExplodeToOwnerspace ... if that also crashes?
    - alfred -
    BTW: you have not commited the transaction.
    Alfred NESWADBA
    Active Contributor
    aliensinearth
    Message 3 of 13 (285 Views)
    11-25-2013 12:07 AM in reply to: Alfred.NESWADBA
    Hi Alfred,
    Thanks for your response.
    For your second question,
    I first tried with the explode only, by creating new dbobject collection object
    BlockTableRecord curSpace = tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite) as BlockTableRecord;
    br.Explode(dboc); // same problem here
    foreach (Entity e in dboc)
    curSpace.AppendEntity(e);
    tr.AddNewlyCreatedDBObject(e, true);
    I got the same fatal error. After that only I changed to ExplodeToOwnerspace.
    For your first question,
    Sorry. I don't know how to verify owner?
    Alfred.NESWADBA
    Message 4 of 13 (282 Views)
    11-25-2013 12:14 AM in reply to: aliensinearth
    Every object has a property .OwnerID that gives you the ObjectID to the owner object.
    As there are some differences in the usage of dynamic blocks and the resulting anonymous blocks can you upload a sample drawing that shows the problem when running your code?
    - alfred -
    Alfred NESWADBA
    Active Contributor
    aliensinearth
    Message 5 of 13 (277 Views)
    11-25-2013 12:24 AM in reply to: Alfred.NESWADBA
    Here I found the problem when I debugged.
    In my code, there are two objectid collection.
    1. ObjectIdCollection oidc1 = btr.GetAnonymousBlockIds();
    2. ObjectIdCollection oidc2 = btr.GetBlockReferenceIds(true, false);
    when I tried with the second object "oidc2" it works fine.
    foreach (ObjectId id in oidc2)
    The problem is with the first object "oidc1".
                        br.ExplodeToOwnerSpace(); // Problem
     In the above code,  the "br" object is null. That is why the autocad is crashing when trying to explode null object.
    Can you help me now how to explode annonumous blocks?
    This is code, we have to change.
    (Thanks for your immediate response)
    Alfred.NESWADBA
    Message 6 of 13 (274 Views)
    11-25-2013 12:29 AM in reply to: aliensinearth
    And when you check the following two properties (before accessing the blockreference):
       id.isValid
       id.isErased
    how are they set?
    - alfred -
    Alfred NESWADBA
    Active Contributor
    aliensinearth
    Message 7 of 13 (271 Views)
    11-25-2013 12:33 AM in reply to: Alfred.NESWADBA
    id.isValid = true;
    id.isErased = false;
    Alfred.NESWADBA
    Message 8 of 13 (268 Views)
    11-25-2013 12:36 AM in reply to: aliensinearth
    can you upload a drawing that shows that problem?
    And let us know what type of AutoCAD (vertical product?), what release and what servicepack you have.
    - alfred -
    Alfred NESWADBA
    Active Contributor
    aliensinearth
    Message 9 of 13 (265 Views)
    11-25-2013 12:48 AM in reply to: Alfred.NESWADBA
    Here is the attached drawing.
    Active Contributor
    aliensinearth
    Message 10 of 13 (254 Views)
    11-25-2013 01:03 AM in reply to: Alfred.NESWADBA
    Sorry. I didn't see the second question.
    My Autocad Version is Autocad 2011 MEP.
    I don't know about service pack.
