.NET
Active Contributor
jprisbe
Message 1 of 4 (820 Views)
Getting command-line parameters
820 Views, 3 Replies
07-11-2012 08:33 AM
From my .NET dll I need to get the command line parameters that were used when AutoCAD was launched.
In the unmanaged world I used acedGetAcadWinApp.
Is there a .NET equivalent?
 //"C:\Program Files\AutoCAD 20xx\acad.exe" /p "..\Acad.arg" /myArg1 /nologo
//Command: args
//Arg0="D:\Program Files\AutoCAD 20xx.exe"
//Arg1="/p"
//Arg2="..\Acad.arg"
//Arg3="/myArg1"
//Arg4="/nologo"
[CommandMethod("Args")]
public void GetAcadArguments()
Document dwg = Application.DocumentManager.MdiActiveDocument;
Editor ed = dwg.Editor;
int i = 0;
foreach (string arg in Environment.GetCommandLineArgs())
ed.WriteMessage("\n Arg{0}=\"{1}\"",i++,arg);
chiefbraincloud
Message 2 of 4 (806 Views)
Re: Getting command-line parameters
07-11-2012 10:21 AM in reply to: jprisbe
Not that I am aware of.
It appears that acedGetAcadWinApp can be PInvoked, but I'm not sure how you would access the properties from the Pointer that is returned.
the signature for 32bit AutoCAD 2012 appears to be ?acedGetAcadWinApp@@YAPAVCWinApp@@XZ
SENL1362
Message 3 of 4 (800 Views)
07-11-2012 10:49 AM in reply to: chiefbraincloud
        //Command: args
        //Arg1="/p"
        //Arg3="/myArg1"
        //Arg4="/nologo"
                int i = 0;
Active Contributor
jprisbe
Message 4 of 4 (796 Views)
07-11-2012 11:04 AM in reply to: jprisbe
Environment.GetCommandLineArgs() is exactly what I was looking for.
Thanks.
