.NET
Getting an intersecting point coordinate of two polylines(lines)
6 REPLIES 6
dynamicscope
6669 Views, 6 Replies
Hi, I wonder if there is a way to get an intersecting point coordinate of two polylines(lines) programmatically.
For example, like in the below sample picture, I need to get coordinates of the points in the red cycles.
Is there any method that I can easily use?
Could I get a sample code snippet that computes the coordinates? (in C# & ObjectARX 2010 if possible?)
I've looked up "Through the Interface" and this disscussion group. couldn't find any useful yet.
Please someone help me. =(
Thank you for your time.
Jake
6 REPLIES 6
Hallex
in reply to: dynamicscope
Check this out
        [CommandMethod("checkinters")]
        public void CheckInterference()
            Database db = HostApplicationServices.WorkingDatabase;
            Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
            Editor ed = doc.Editor;
                Transaction tr = db.TransactionManager.StartTransaction();
                using (tr)
                    try
                        BlockTableRecord btr = (BlockTableRecord)tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite);
                        PromptEntityOptions peo = new PromptEntityOptions("\nSelect a first polyline  >>");
                        peo.SetRejectMessage("\nSelected object might be of type polyline only >>");
                        peo.AddAllowedClass(typeof(Polyline), false);
                        PromptEntityResult res;
                        res = ed.GetEntity(peo);
                        if (res.Status != PromptStatus.OK)
                            return;
                        Entity ent = (Entity)tr.GetObject(res.ObjectId, OpenMode.ForRead);
                        if (ent == null)
                            return;
                        Polyline poly = (Polyline)ent as Polyline;
                        peo = new PromptEntityOptions("\nSelect second polyline  >>");
                            return;
                        if (ent == null)
                            return;
                        Polyline poly2 = (Polyline)ent as Polyline;
                        Point3dCollection pts = new Point3dCollection();
                        poly.IntersectWith(poly2, Intersect.OnBothOperands, pts, (int)IntPtr.Zero, (int)IntPtr.Zero);
                        Autodesk.AutoCAD.ApplicationServices.Application.ShowAlertDialog(string.Format("Hint:\nNumber of Verices: {0}\nNumber of Intersections: {1}", poly.NumberOfVertices, pts.Count));
                     // test for visulization only
                        foreach (Point3d pt in pts)
                            Circle circ = new Circle(pt,Vector3d.ZAxis,10 * db.Dimtxt);
                            circ.ColorIndex = 1;
                            btr.AppendEntity(circ);
                            tr.AddNewlyCreatedDBObject(circ, true);
                        tr.Commit();
                    catch (System.Exception ex)
                        ed.WriteMessage("\n{0}\n{1}", ex.Message, ex.StackTrace);
~'J'~
_____________________________________
C6309D9E0751D165D0934D0621DFF27919
Hallex
Can you upload the piece of this drawing
for testing?
~'J'~
dynamicscope
in reply to: Hallex
It does work!! Thank you!! 😃
Hallex
You're welcome
Happy coding Smiley Happy
~'J'~
Hi, i need to get coordinates of an image in autocad for my final year project. I am a student of computer engineering so dont have autocad background. Any help will highly be appriciated, thankyou.
amitnkukanur
in reply to: Hallex
After long time i am back to customization.
In this above code, rather than user selecting polylines, can't we use select all option to check interferece.
if yes what are the changes to be made to the above code.
Amit
Senior Software Engineer
”Boost
