.NET
Getting a unique ID from blocks
5 REPLIES 5
hakand
3568 Views, 5 Replies
Hey guys,
Just wondering how I would be able to get a unique ID of a block?
Currently I tried all the properties of a block table record that resemble anything to do with an ID like btr.objectID and btr.ID although copies of blocks have the same ID as the original and the copies contain different attribute values so I wish to access the copies by just feeding in one ID (that I have grabbed from every block in the drawing and put into an array).
Is there a number that is unique to every individual block is essentially what I'm asking, and if so, how do I access it?
Cheers!
5 REPLIES 5
Alfred.NESWADBA
in reply to: hakand
Please don't mix up "BlockTableRecord" and "BlockReference"!
BlockTableRecord is the definition how a symbol is defined
BlockReference is then the inserted object (in ModelSpace or PaperSpace or within anther BlockTableRecord).
And for any item in the DWG-database you have the ObjectID and the Handle.Value that is the unique identifier of an object within the database. IMPORTANT: it's only unique within one drawing, in two drawings you may have the same ObjectID or Handle.
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
hakand
in reply to: Alfred.NESWADBA
Ahh thank you Alfred! I did get them confused.
So my current code feeds in the btr.id, find the attribute category then adds the value to the array:
Public Sub match_nonconstant_to_blockgrouparray(ByVal blkid As Object)
        Dim doc As Document = Application.DocumentManager.MdiActiveDocument
        Dim ed As Editor = Application.DocumentManager.MdiActiveDocument.Editor
        Dim db As Database = HostApplicationServices.WorkingDatabase
        Dim tr As Transaction = db.TransactionManager.StartTransaction()
        Try
            Dim btr As BlockTableRecord = TryCast(blkid.GetObject(OpenMode.ForRead), BlockTableRecord)
            Dim ids As ObjectIdCollection = btr.GetBlockReferenceIds(True, True)
            Dim btrId As ObjectId
            For Each btrId In ids
                Dim blkref As BlockReference = TryCast(btrId.GetObject(OpenMode.ForRead, False), BlockReference)
                Dim attCol As AttributeCollection = blkref.AttributeCollection
                For Each attId As ObjectId In attCol
                    Dim attRef As AttributeReference = DirectCast(tr.GetObject(attId, OpenMode.ForRead), AttributeReference)
                    If attRef.Tag.ToUpper = "CATEGORY" Then
                        blockgrouparray(z) = attRef.TextString
                    End If
                Next
            Next
        Catch ex As Autodesk.AutoCAD.Runtime.Exception
            ed.WriteMessage(("Exception: " + ex.Message))
        Finally
            tr.Dispose()
        End Try
    End Sub
Would I change the code so that it just skips the whole blkid part? So its like this:
Public Sub match_nonconstant_to_blockgrouparray(ByVal blkref As Object)
        Try
                    End If
            Next
        Finally
            tr.Dispose()
        End Try
    End Sub
Many thanks,
HD
hakand
in reply to: hakand
Okay so I just figured out my issue there, I was bringing in the blkref as an Object type rather than a Block Reference type.
Now, my next question is, since looking at constant attributes requires you to look at the block table record and cycle through the attribute definitions, how can I find a block's constant by feeding into a function, the block reference ID?
Currently I am feeding in the btr.ID with this function:
  Public Sub match_constant_to_blockgrouparray(ByVal blkid As Object)
        Try
            For Each id As ObjectId In btr
                Dim ad As AttributeDefinition = TryCast(tr.GetObject(id, OpenMode.ForRead), AttributeDefinition)
                If ad IsNot Nothing Then
                    If ad.Constant = True Then
                        If ad.Tag.ToUpper = "CATEGORY" Then
                            blockgrouparray(z) = ad.TextString
                        End If
                    End If
                End If
            Next
        Finally
            tr.Dispose()
        End Try
    End Sub
Many Thanks,
HD
Alfred.NESWADBA
in reply to: hakand
sorry, for me it's not clear what you want to do.
Can you describe it again with other words or by attaching a sample-drawing? With the sample-drawing we have the chance to talk about "blocknames" and "modelspace" so it's more clear and we don't get confused by BlockTableRecord and BlockReference, not by AttribtueDefinition and AttributeReference, ....
- alfred -
Alfred NESWADBA
hakand
in reply to: hakand
Sorry Alfred, I was able to figure out the answer the other day. What I meant was 'How do I feed in a block ref into a routine and get the attribute constant?' Before my routine that did this only used the block table record so I had to add in a Directcast to include the block table record.
Thanks again for your help!
HD
”Boost
