.NET
GetString with Keywords FATAL ERROR
11 REPLIES 11
Message 1 of 12
matus.brlit
2509 Views, 11 Replies
i encountered a problem, when I try to use GetString with Keywords
Dim optString As New PromptStringOptions("Zadaj nazov: ")
optString.Keywords.Add("Vypisat")
Dim resPrompt As PromptResult = ed.GetString(optString)
AutoCAD crashes with FATAL ERROR on the last line.
11 REPLIES 11
Message 2 of 12
Paulio
in reply to: matus.brlit
You need to use PromptKeywordOptions like this:
            Dim optstring As New PromptKeywordOptions("Zadaj nazov: ")
            optstring.Keywords.Add("Vypisat")
            Dim resPrompt As PromptResult = ed.GetKeywords(optstring)
 Hope that helps.
Message 3 of 12
Hallex
You can't add keywords to Getstring method
But you might be want to use DefaultValue property
to get possibility for empty input
And also you always use Try.. Catch statement to
save your working time Smiley Happy
See sample:
        Public Sub testkwords()
            Dim doc As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
            Dim db As Database = doc.Database
            Dim ed As Editor = doc.Editor
            Try
                optString.UseDefaultValue = True
                optString.AppendKeywordsToMessage = True
                optString.DefaultValue = "Vypisat"
                If resPrompt.Status <> PromptStatus.OK Then
                    Return
                Dim strRes As String = resPrompt.StringResult
                MsgBox(strRes)
            Catch ex As System.Exception
                MsgBox(ex.Message + vbCrLf + ex.StackTrace)
            Finally
            End Try
        End Sub
~'J'~
_____________________________________
C6309D9E0751D165D0934D0621DFF27919
Message 4 of 12
matus.brlit
to Paulio: keyword prompt only allows to enter keyword, i want an user inputed string, or a keyword
to Hallex: Thanks for the workaround. That's strange, that PromptStringOptions has a Property Keywords and then throws an exception saying Keywords are not allowed.
I think that I will have to stick with this, but it's strange to have a Keyword in <> instead of [], very odd behavior. Whay if I wanted to have more than one keyword?
Message 5 of 12
Hallex
If you need to add more than one keyword
you have to use ed.getkword method, see examples,
hope you will be undrerstand how to use this functions,
feel free to adopt them to your needs:
        Function PromptKeyWords(ByVal PromptStr As String, ByVal kwords As String(), ByVal deflt As String) As Boolean
            Dim ed As Editor = Application.DocumentManager.MdiActiveDocument.Editor
            Dim prOpt As PromptKeywordOptions = New PromptKeywordOptions(PromptStr)
            Dim prRes As PromptResult = Nothing
            prOpt.AppendKeywordsToMessage = True
            For Each wd As String In kwords
                prOpt.Keywords.Add(wd)
            Next
            prOpt.Keywords.Default = deflt
            prOpt.SetMessageAndKeywords(PromptStr, "[Yes/No]")
            prOpt.Keywords.Add("[")
            prRes = ed.GetKeywords(prOpt)
            If prRes.Status = PromptStatus.Cancel Then
                MsgBox("Error: user cancelled")
                Return False
            Else
                MsgBox(prRes.StringResult)
                Return True
        End Function
        Public Shared Function GetKwordOut(ByVal ed As Editor, ByVal msg As String, ByVal kwords As String()) As String
            Dim pko As New PromptKeywordOptions(vbLf + msg)
            pko.AllowNone = True
            For Each itm As String In kwords
                pko.Keywords.Add(itm)
            Next
            pko.Keywords.Default = kwords.GetValue(kwords.Length - 1).ToString()
            Dim pkr As PromptResult = ed.GetKeywords(pko)
            If pkr.Status <> PromptStatus.OK Then
                Return String.Empty
            Else
                Return pkr.StringResult
        End Function
~'J'~
Message 6 of 12
matus.brlit
in reply to: Hallex
Hallex, you didn't understand what I meat.
I want a string prompt, i want user to be able to enter a string, any string and also be able to choose a keyword for some action. But I guess it's not possible.
Message 7 of 12
Hallex
Sorry, Matus
I have disagreed completely
You didn't understand how to use the function I posted
Please, try complete solution:
       <CommandMethod("MatusBrilt", "matus", CommandFlags.Modal)> _
    Public Sub SampleTest()
        Dim kwords As String() = {"Rectangle", "Circle", "Ellipse", "Squiggle"}
        Dim strout As String = GetKwordOut(ed, vbLf + "Choose a Shape Type or Enter Another Type You Want: ", kwords)
        ed.WriteMessage(vbLf + "{0}", strout)
    End Sub
        pko.AllowArbitraryInput = True
        Next
            Return String.Empty
        Else
    End Function
~'J'~
Message 8 of 12
matus.brlit
in reply to: Hallex
If I enter anything else in the eg.GetKeywords prompt, I get an error "Invalid option keyword." and I am prompted again.
I use AutoCAD 2012.
Message 9 of 12
Hallex
You have to copy code I posted in the last post because I've added
ArbitaryInput=True in this function
Then it will be work as you need, see what I have a got after running the code
(tested on 2010th) :
Command: MATUS Choose a Shape Type or Enter Another Type You Want [Rectangle/Circle/Ellipse/Squiggle] <Squiggle>: Trapezoid
 Trapezoid
 Command:
~'J'~
Message 10 of 12
matus.brlit
in reply to: Hallex
oh, finally 🙂
thank you very much, I missed that one
Message 11 of 12
Hallex
You're welcome
Happy coding Smiley Happy
~'J'~
Message 12 of 12
Alfred.NESWADBA
in reply to: Hallex
great suggestion, helped me out 😉
thx, - alfred -
Alfred NESWADBA
(not an Autodesk consultant)
”Boost
