.NET
Valued Contributor
Nawara17
Message 1 of 8 (116 Views)
GetFirst()???
116 Views, 7 Replies
08-16-2006 03:56 PM
Hi all,
Please can anybody help.
Where can i find getFirst method, it belongs to what(Autodesk.AutoCAD.What??) ??
coz I am creating my own command that when i double click on a block it will do the following:
[Autodesk.AutoCAD.Runtime.CommandMethod("Details",CommandFlags.UsePickSet)]
public void BlockInfo()
Document activeDoc = AcadAPP.DocumentManager.MdiActiveDocument;
PromptSelectionResult res = activeDoc.Editor.SelectImplied();
if (res.Status != PromptStatus.OK)
MessageBox.Show("No Objects selected.");
return;
if (res.Value.Count != 1)
MessageBox.Show("More than one object is selected. \nPlease, select only one object.");
return;
ObjectId id=res.Value[0].ObjectId;
but the problem with that code is activeDoc.Editor.SelectImplied();
it always gives 0 objects selected.
i found in http://www.codeproject.com/useritems/arxref.asp a help document that had this Info:
UsePickSet: When the pickfirst set is retrieved, it is cleared within AutoCAD.Command is able to retrieve the pickfirst set via the method Getfirst().
but I don't know how can i get this method in which library??
thanks in advance :smileyhappy:
Noora
*Paul Richardson
Message 2 of 8 (116 Views)
Re: GetFirst()???
08-16-2006 05:12 PM in reply to: Nawara17
Use the "Object Browser".
Try this:
Editor ed = Autodesk.AutoCAD.ApplicationServices.
Application.DocumentManager.MdiActiveDocument.Editor;
wrote in message news:5270942@discussion.autodesk.com...
Hi all,
do the following:
return;
object.");
return;
that had this Info:
Getfirst().
Noora
Valued Contributor
Nawara17
Message 3 of 8 (116 Views)
Re: GetFirst()???
08-16-2006 06:23 PM in reply to: Nawara17
hello Paul,
Please, Can you answer my question??
*Paul Richardson
Message 4 of 8 (116 Views)
Re: GetFirst()???
08-16-2006 06:36 PM in reply to: Nawara17
What question do you want answered? When I am looking
for info I use the "Object Browser". You can filter just the
Acad managed libraries, and then use the search box. For
docs you must use the native ones in the ARX sdk.
Did you try the way I said? It works for me, but I'm still
finding my way too.
[code]
PromptSelectionResult psr = ed.SelectImplied();
[/code]
wrote in message news:5270994@discussion.autodesk.com...
hello Paul,
Valued Contributor
Nawara17
Message 5 of 8 (116 Views)
Re: GetFirst()???
08-16-2006 07:42 PM in reply to: Nawara17
thanks alot pual for your answer.
i have another question. can i use selecImplied() for blockreference?
what i want to say is double clicking on a block refernce invokes eattedit without highlighting the block.
I redefined eattedit command, but selectImplied() always gives me 0 object selected. i think becuase of unhighlighting the block while double clicking it. is that right?
how can i solve this problem? please,anyone can help
*Paul Richardson
Message 6 of 8 (116 Views)
Re: GetFirst()???
08-16-2006 08:27 PM in reply to: Nawara17
Sorry I missed the doubleclick part.
You can set Double Click Action in 07 via the CUI.
Also check out "DoubleClickAction" in the arxref.chm,
and the cui sample in the sdk.
Pre-07 you can do this using acdbdoubleclickedit in
native ARX. I don't know about managed. If it's
possible someone else should chime in.
wrote in message news:5271003@discussion.autodesk.com...
it. is that right?
Valued Contributor
Nawara17
Message 7 of 8 (116 Views)
Re: GetFirst()???
08-17-2006 07:38 AM in reply to: Nawara17
thanks pual. i'll search for that and i'll post what i find :smileyhappy:
*Paul Richardson
Message 8 of 8 (116 Views)
Re: GetFirst()???
08-17-2006 03:08 PM in reply to: Nawara17
Meant the managed ones in the ARX sdk. Althought the
native ones help too.
"Paul Richardson" wrote in message
news:5271025@discussion.autodesk.com...
finding my way too.
[code]
[/code]
hello Paul,
Post to the Community
New Post
Announcements
Are You Going To Be @ AU 2014? Feel free to drop by our AU topic post and share your plans, plug a class that you're teaching, or simply check out who else from the community might be in attendance. Ohh and don't forgot to stop by the Autodesk Help | Learn | Collaborate booths in the Exhibit Hall and meet our community team if you get a chance!
