.NET
GetBoundingBox is Returning 0
1 REPLY 1
amitnkukanur
323 Views, 1 Reply
This is a part of my code which i am using to calculate the locations of Texts using GetBoundingBox. The problem is GetBoundingBox is Returning 0 when i execute the code.
For index As Integer = 0 To100
' Get single item from selection
Dim AcEnt As Object = AcSpace.GetType.InvokeMember("Item", BindingFlags.InvokeMethod, Nothing, AcSpace, New Object() {index})
' Get Object name
Dim objName As String = AcEnt.GetType.InvokeMember("ObjectName", BindingFlags.GetProperty, Nothing, AcEnt, Nothing).ToString()
Dim textStr As String = String.Empty
If objName = "AcDbText" Then
textStr = AcEnt.GetType.InvokeMember("TextString", BindingFlags.GetProperty, Nothing, AcEnt, Nothing).ToString()
Dim aPoint1(2) As Double
Dim aPoint2(2) As Double
Dim params As Object
params = {aPoint1, aPoint2}
Dim DataParam As Double = AcEnt.GetType().InvokeMember("GetBoundingBox", BindingFlags.InvokeMethod, Nothing, AcEnt, params)
Next
Can you suggest me how to get locations of Texts
Senior Software Engineer
1 REPLY 1
Hallex
in reply to: amitnkukanur
See my last code here:
http://forums.autodesk.com/t5/NET/Select-All/td-p/3551324
~'J'~
_____________________________________
C6309D9E0751D165D0934D0621DFF27919
”Boost
