.NET
phil
Message 1 of 5 (765 Views)
GetAcadDocument
765 Views, 4 Replies
03-28-2012 04:31 PM
I'm having trouble trying to get the GetAcadDocument method to work.
2012 code:
ThisDrawing = DocumentManager.MdiActiveDocument.AcadDocument
2013:
ThisDrawing = DocumentExtension.GetAcadDocument(Application.DocumentManager.MdiActiveDocument)
Produces a run time error.  I know just enough .net to brute force my app to do what I want and would appreciate any help.
Phil
Alfred.NESWADBA
Message 2 of 5 (747 Views)
Re: GetAcadDocument
03-28-2012 11:29 PM in reply to: phil
for me it's running (it used time to find the alternative to .AcadDocument but with the method same to yours it's working for me. How is ThisDrawing declared at your code, what runtime-error do you get exactly?
- alfred -
Alfred NESWADBA
phil
Message 3 of 5 (728 Views)
Re: GetAcadDocument
03-29-2012 08:44 AM in reply to: Alfred.NESWADBA
Thanks for the response Alfred...confirming the code was ok made me look for a more fundamental problem and I realized I had a bad reference.
Active Member
jrenatto
Message 4 of 5 (358 Views)
Re: GetAcadDocument
07-26-2013 08:25 AM in reply to: phil
Greetings, I have the same problem you had, I would like you to help me solve mine, with some questions
. How did you fix it?
- Versiond and vb.net What did you use?
- What version of AutoCAD are you?
- What references did you use?
I await your reply, thanks.
_gile
Message 5 of 5 (325 Views)
Re: GetAcadDocument
07-28-2013 03:50 AM in reply to: jrenatto
Just a little precision about GetAcadDocument() method.
It's an extension method which extents the Document type (defining extension isn't exactly the same with C# or VB).
Extension methods can be called both way (assuming doc = MdiActivedocument):
- as static (Shared) methods as shown upper:
ThisDrawing = DocumentExension.GetAcadDocument(doc)
- as instance methods of the extended type:
ThisDrawing = doc.GetAcadDocument():
The second one will directly work with C# because DocumentExtension is a class of the ApplicationServices namespace.
But with VB extension methods have to be defined in a Module, so, the DocumentExtension module have to be imported for this behavior to be available.
Imports Autodesk.AutoCAD.ApplicationServices.DocumentExtension
Gilles Chanteau
