.NET
GetAcadDocument
6 REPLIES 6
Pfilc
2680 Views, 6 Replies
GetAcadDocument
I'm having trouble trying to get the GetAcadDocument method to work.
2012 code:
ThisDrawing = DocumentManager.MdiActiveDocument.AcadDocument
2013:
ThisDrawing = DocumentExtension.GetAcadDocument(Application.DocumentManager.MdiActiveDocument)
Produces a run time error.  I know just enough .net to brute force my app to do what I want and would appreciate any help.
Phil
6 REPLIES 6
Alfred.NESWADBA
in reply to: Pfilc
for me it's running (it used time to find the alternative to .AcadDocument but with the method same to yours it's working for me. How is ThisDrawing declared at your code, what runtime-error do you get exactly?
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
Pfilc
in reply to: Alfred.NESWADBA
Thanks for the response Alfred...confirming the code was ok made me look for a more fundamental problem and I realized I had a bad reference.
jrenatto
in reply to: Pfilc
Greetings, I have the same problem you had, I would like you to help me solve mine, with some questions
. How did you fix it?
- Versiond and vb.net What did you use?
- What version of AutoCAD are you?
- What references did you use?
I await your reply, thanks.
_gile
in reply to: jrenatto
Just a little precision about GetAcadDocument() method.
It's an extension method which extents the Document type (defining extension isn't exactly the same with C# or VB).
Extension methods can be called both way (assuming doc = MdiActivedocument):
- as static (Shared) methods as shown upper:
ThisDrawing = DocumentExension.GetAcadDocument(doc)
- as instance methods of the extended type:
ThisDrawing = doc.GetAcadDocument():
The second one will directly work with C# because DocumentExtension is a class of the ApplicationServices namespace.
But with VB extension methods have to be defined in a Module, so, the DocumentExtension module have to be imported for this behavior to be available.
Imports Autodesk.AutoCAD.ApplicationServices.DocumentExtension
Gilles Chanteau
GileCAD
GitHub
cadcamm99
in reply to: _gile
Gilles,
I am moving over my VB app to C#.
I used this in VB
Public ReadOnly Property ThisDrawing() as AcadDocument
     Get
          Return
               Core.Application.DocumentManager.MdiActiveDocument.GetAcadDocument()
     End Get
End Property
then in a different sub
ThisDrawing.ObjectSnapMode = False
However I couldn't do this in C# so I tried:
private readonly Document roDocument = Autodesk.AutoCAD.ApplicationServices.Core.Application.DocumentManager.MdiActiveDocument;
public object ThisDrawing
     get
          return roDocument.GetAcadDocument();
ThisDrawing.ObjectSnapMode = False   - however ObjectSnapMode does not come up.
Do you have any ideas?
norman.yuan
in reply to: cadcamm99
Your C# code
     get
is not exactly equivalent to the original VB.NET code:
     Get
          Return
     End Get
End Property
In the VB.NET code, the property ThisDrawing is a type of AcadDocument (you must had reference to AutoCAD's COM API), while in the C# code, the same property ThisDrawing is type of object, thus you cannot have code like ThisDrawing.ObjectSnapMode=..... To make the C# code the same as VB.NET, you need to add reference to AutoCAD COM API and expose the property ThisDrawing as AcadDocument.
BTW, unless it is really necessary, in most cases, there is no need to mix COM APIs in the .NET API development, especially the VBA style of "ThisDrawing" shown in various code examples available on the net is bad-taste code used in AutoCAD .NET API programming, IMO.
Norman Yuan
Drive CAD With Code
”Boost
