We are building a product using the AutoCAD .NET API and Visual Studio 2008 SP1.
Our product needs to support AutoCAD 2007 through 2010.
Environment:
The OS is XP Professional SP3 and has the following (relevant) programs:
1. AutoCAD 2007, 2008 and 2010, Autodesk DWF Viewer 7, Autodesk Design Review 2010
2. .NET Framework 1.1 thru 3.5 SP1
If it matters, this is all running in a VM.
Visual Studio project details:
I have a project reference to the following AutoCAD DLLs:
1. C:\Program Files\AutoCAD 2007\acdbmgd.dll (Version 17.0.209.0)
2. C:\Program Files\AutoCAD 2007\acmgd.dll (Version 17.0.209.0)
3. The "AutoCAD 2008 Type Library" COM component
4. The "OLE Automation" COM component
Problem:
When I run the project (with or without debug mode), I get the following System.Reflection.ReflectionTypeLoadException:
{"Unable to load one or more of the requested types. Retrieve the LoaderExceptions property for more information."}
Here's the value of LoaderException property:
{"Could not load file or assembly 'acdbmgd, Version=17.0.209.0, Culture=neutral, PublicKeyToken=null' or one of its dependencies. Invalid pointer (Exception from HRESULT: 0x80004003 (E_POINTER))":"acdbmgd, Version=17.0.209.0, Culture=neutral, PublicKeyToken=null"}
If it helps, here are other details:
Source: mscorlib
StackTrace:
at System.Reflection.Module._GetTypesInternal(StackCrawlMark& stackMark)
at System.Reflection.Assembly.GetTypes()
at Microsoft.VisualStudio.Tools.UserControlTestContainer.LoadAssemblyFromFile(String fileName)
at Microsoft.VisualStudio.Tools.UserControlTestContainer.UserControlTestContainer_Load(Object sender, EventArgs e)
at System.Windows.Forms.Form.OnLoad(EventArgs e)
at System.Windows.Forms.Form.OnCreateControl()
at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
at System.Windows.Forms.Control.CreateControl()
at System.Windows.Forms.Control.WmShowWindow(Message& m)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
at System.Windows.Forms.ContainerControl.WndProc(Message& m)
at System.Windows.Forms.Form.WmShowWindow(Message& m)
at System.Windows.Forms.Form.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.DebuggableCallback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
at System.Windows.Forms.SafeNativeMethods.ShowWindow(HandleRef hWnd, Int32 nCmdShow)
at System.Windows.Forms.Control.SetVisibleCore(Boolean value)
at System.Windows.Forms.Form.SetVisibleCore(Boolean value)
at System.Windows.Forms.Control.set_Visible(Boolean value)
at System.Windows.Forms.Application.ThreadContext.RunMessageLoopInner(Int32 reason, ApplicationContext context)
at System.Windows.Forms.Application.ThreadContext.RunMessageLoop(Int32 reason, ApplicationContext context)
at System.Windows.Forms.Application.Run(Form mainForm)
at Microsoft.VisualStudio.Tools.UserControlTestContainer.Main(String[] args)
I am not sure why I am getting this error. Any help would be greatly appreciated. Thanks.
- Aashish
