.NET
Get the Bounding box of Text and MText
5 REPLIES 5
wesbird
1719 Views, 5 Replies
I just found GeomExtents does not return the correct bounding box information of text and mtext in C#. I know I can do it with COM Interop. but it will slow. So is there any way I can do it in pure manage code? sample would be great.
Thank you very much
Wes
Windows 10 64 bit, AutoCAD (ACA, Map) 2023
5 REPLIES 5
wesbird
in reply to: wesbird
I just found GetBoundingPoints for MText. Is anyone use this function? any experise?
Thank you
Wes
Any reason you can't use the ActualWidth and
ActualHeight properties?
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2004/2005/2006
http://www.acadxtabs.com
wrote in message news:5103180@discussion.autodesk.com...
Thank you very much
Wes
wesbird
ActualWidth and ActualHeight only have the size, I also need the location. Is this doable?
Thank you, Tony. I also learn a lot from your other post.
Wes
How about the Location property?
wrote in message news:5103529@discussion.autodesk.com...
Wes
wesbird
GetBoundingPoints work prefect for MTEXT, now the question is how about TEXT?
Thank you,
Wes
”Boost
