.NET
Member
emiz
Message 1 of 3 (493 Views)
Get text real height on screen
493 Views, 2 Replies
07-31-2014 08:28 AM
Hi, I have align vertically some MText objects in a drawing. They have the Text Height property as 2.5 but on the screen they occupy a larger area (see attachement). How can I get or calculate the active height? I've tried the GeometricExtents but that doesn't help.
thank you
emiz
I believe what you need is these 2 properties: MText.ActualWidth and MText.ActualHeight
MText's GeometricExtents varies depending on MText's Height/Width (Defined Width and Defined Height shown in properties window). If Width/Height is greater than the ActualWidth/ActualHeight (as your picture shows), then the GeometricExtents is the same as the Width/Height. However, MText's Width/Height can be set to less than ActualWidth/Height, or even be 0.0. In this case, the GeometricExtents wil be the same as ActualWidth/Height.
norman.yuan
Message 2 of 3 (472 Views)
Re: Get text real height on screen
07-31-2014 10:04 AM in reply to: emiz
Member
emiz
Message 3 of 3 (453 Views)
07-31-2014 12:50 PM in reply to: norman.yuan
Hi Norman,
thank you very much, your suggestion solved my problem.
emiz
