How can I Get table name of the object data of a selected layer, with C#.
Thanks.
if you speak about "object data" do you mean the objectdata from Map3D?
If so ==> you can't assign layers objectdata (afaik). what do you mean by "selected layer"
If not ==> what do you mean by "object data".
So for both cases I guess the question is not detailed enough. Can you please give us a bit more info (maybe a sample drawing with a description what we should find there).
- alfred -
I am working with Map3D. The objectdata from Map3D when attached can be given a name or takes the default layer name. By iterating through the Layer table can give each layer name. eg.
using (Transaction acTrans = acCurDb.TransactionManager.StartTransaction()) { LayerTable acLyrTbl; acLyrTbl = acTrans.GetObject(acCurDb.LayerTableId,OpenMode.ForRead) as LayerTable; // Step through the Layer table and print each layer name foreach (ObjectId acObjId in acLyrTbl) { LayerTableRecord acLyrTblRec; acLyrTblRec = acTrans.GetObject(acObjId, OpenMode.ForRead) as LayerTableRecord; acDoc.Editor.WriteMessage("\n" + acLyrTblRec.Name); }
But I want to get the objectdata table name of the active layer only. (The one in green color with the tick mark) Is it possible.?
Thanks.
Yep, you can give the objectdatatable a name
>> [...] or takes the default layer name
No, that I don't understand. If you create a objectdatatable it has nothing to do with layers .... or I miss something or I misunderstand something ;(
I guess you are asking not for objectdata, but for the layertable and layertablerecord of the active layer? If so then try this:
'get the ID from the current layer Dim tLayID As DatabaseServices.ObjectId = acCurDB.Clayer 'get the LayerTableRecord for the current layer Dim tLayTabRec As DatabaseServices.LayerTableRecord = CType(acTrans.GetObject(tLayID, DatabaseServices.OpenMode.ForRead), DatabaseServices.LayerTableRecord)
...and the LayerTableRecord can give you now all about the layer you like to have, like the .Name property.
To make sure what I mean by "objectdata": >>>click<<<
HTH, - alfred -
Sorry, May be I am not able to present what I me, as I am quite new to some of the Autocad terminologies.
I what to get the name of this objectdatatable attached to that layer(maybe called so, in my example "C_12_Point"). But when I imported the SHP with the attributes attached to it, I named the objectdatatable as "TestTable" .
The code you had attached displays the current active layer as "C_12_Point" in my example. But I want the output as "TestTable".
thanks.
