.NET
.NET
Valued Contributor
1 Kudo
Post 1 of 13
Get specified attribute from block without loop.
531 Views, 12 Replies
08-09-2012 01:33 PM
Hello!
I know how to get/set attribute within loop at block's AttributeCollection.
But I'm wonder if I can set value for specified attribute without loop. Or I always have to iterate on each attribute in block's AttributeCollection?
Thanks.
chiefbraincloud,
I too don't like passing transactions around but I won't open a new while a TopTransaction is running.
Disposing the Attribute References that you open is unnecessary because it's opened with the transaction which will dispose it for you.
By my side, I use some extension methods with Dictionary<string, string>.
Here's an extract:
 public static class AttributeExtensions
public static IEnumerable<AttributeReference> GetAttributes(this AttributeCollection attribs)
foreach (ObjectId id in attribs)
yield return (AttributeReference)id.GetObject(OpenMode.ForRead, false, false);
public static Dictionary<string, string> GetAttributesValues(this BlockReference br)
return br.AttributeCollection
.GetAttributes()
.ToDictionary(att => att.Tag, att => att.TextString);
public static void SetAttributesValues(this BlockReference br, Dictionary<string, string> atts)
foreach (AttributeReference attRef in br.AttributeCollection.GetAttributes())
if (atts.ContainsKey(attRef.Tag))
attRef.UpgradeOpen();
attRef.TextString = atts[attRef.Tag];
54 Kudos
Post 2 of 13
Re: Get specified attribute from block without loop.
08-09-2012 03:07 PM in reply to: GrzesiekGP
Only if you store the ids somehow, after the first time you find them, or when you create them, but I can't think of very many scenarios where that would be beneficial.
Valued Contributor
1 Kudo
Post 3 of 13
08-09-2012 03:19 PM in reply to: chiefbraincloud
Thanks for the reply.
I've written own functions to get/set specified attribute (of course with loop using):
        private static string GetAttribute(Transaction tr, BlockReference blkRef, string attribute)
            AttributeCollection attCol = blkRef.AttributeCollection;
            foreach (ObjectId attId in attCol)
                AttributeReference attRef = (AttributeReference)tr.GetObject(attId, OpenMode.ForWrite);
                if (attRef.Tag.ToUpper() == attribute.ToUpper())
                    return attRef.TextString;
            return string.Empty;
        private static void SetAttribute(Transaction tr, BlockReference blkRef, string attribute, string value)
                    attRef.TextString = value;
                    attRef.DowngradeOpen();
If someone see some bad code, please let me know :smileyhappy:
54 Kudos
Post 4 of 13
08-09-2012 03:36 PM in reply to: GrzesiekGP
I personally don't like passing transactions around, and would prefer to open a new transaction inside these functions, but that is my personal preference.
You should, however, be disposing the Attribute References that you open.
Otherwise, I have two functions just like these (In VB), and a couple more that overload them where I can pass in a Dictionary(of String, String) to the Set method, and set the values of multiple attributes in the same transaction, or I can get all the tags and values at once by returning the same kind of dictionary from the Get function.
24 Kudos
Post 5 of 13
08-09-2012 10:13 PM in reply to: GrzesiekGP
AttributeCollection is implemented from the interface ICollection, not from IDictionary. So there is no key-value pair to jump right away to the specified attribute. We expect to have blockReference.AttributeCollection[attributeTagName] = attributeReference, to get a specified attribute without using loop. But AttributeCollection is a .NET collection that is an enumerable list having to deal with iteration loop.
We can write code to create an attribute dictionary of a block, then use it to randomly find the attribute (from ObjectId) based on its unique tag:
public static Dictionary<string, ObjectId> GetAttributeDictionary(BlockReference blockRef)
 var dictionary = new Dictionary<string, ObjectId>();
 using (Transaction tr = blockRef.Database.TransactionManager.StartTransaction())
  AttributeCollection collection = blockRef.AttributeCollection;
  foreach (ObjectId objectId in collection)
   var attribute = (AttributeReference)tr.GetObject(objectId, OpenMode.ForRead);
   dictionary.Add(attribute.Tag, objectId);
  tr.Commit();
 return dictionary;
public static ObjectId GetAttributeFromTagName(BlockReference blockRef, string attributeTag)
 Dictionary<string, ObjectId> dictionary = GetAttributeDictionary(blockRef);
 return dictionary[attributeTag];
-Khoa
54 Kudos
Post 6 of 13
08-09-2012 10:53 PM in reply to: khoa.ho
It is late, and I am a little bleary eyed, and a little tipsy, and I don't mean to be adversarial, or controversial, but that does not help to prevent the iteration of the attribute collection.  It might be the underlying code for storing the IDs as I had originally proposed, but as written it does not store the IDs, it just iterates the collection every time the wrapper function is called, so it saves you nothing.
I've got to get to bed, and trying to read C# code right now is making me dizzy.  I'll look at it again tommorrow and see if I feel differently about it.
253 Kudos
Post 7 of 13
08-09-2012 11:19 PM in reply to: chiefbraincloud
chiefbraincloud,
Here's an extract:
                .GetAttributes()
Gilles Chanteau
Valued Contributor
1 Kudo
Post 8 of 13
08-10-2012 02:51 AM in reply to: GrzesiekGP
Excelent idea with dictionary use :smileyhappy:
Thanks mate!
24 Kudos
Post 9 of 13
08-10-2012 06:36 AM in reply to: chiefbraincloud
Definitely we call the method GetAttributeDictionary() only one time, store in a variable, and use it many times based on specified attribute tag names. The second method (GetAttributeFromTagName) just shows how to find an attribute in the dictionary.
ObjectId is more generic to present an attribute reference. Then we can call GetObject() method to get or update attribute values. AttributeCollection is also a collection of ObjectIds.
-Khoa
54 Kudos
Post 10 of 13
08-10-2012 08:07 AM in reply to: _gile
gile
I also try not to have nested transactions, and I should have also mentioned I don't like passing around open objects, either.  I always pass ObjectIds and open them in the function that is doing the work.
As I mentioned above, I also have two methods that use String, String dictionaries to get or set attributes.  I love dictionaries, but it is not feasable for me to create a String, ObjectId dictionary and leave it memory resident to use later.  I just don't think that is a good idea at all.  My code deals with far too many blocks and attributes to load up the memory like that.
