.NET
Valued Contributor
Ertqwa
Message 1 of 5 (262 Views)
Get short-cuts - open
262 Views, 4 Replies
08-18-2012 11:53 PM
Hello Forum,
if you use AutoCAD's command "open", on the left side there are short-cuts. I want to retreive the names and paths of those shortcuts. How do I get them? I know they are in the registry, but the registry path is quite complicated and I fear the path will be different for other systems with other AutoCAD versions. Or is there some kind of logic to such a registry path of AutoCAD?
Thank you.
Ty for your reply.
the registry key that contains the shortcuts in 'OPEN' looks something like this for AutoCAD2009:
HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R17.2\ACAD-7005:409\Profiles\<<Profile>>\Dialogs\AllAnavDialogs
 R17.2 means it is AutoCAD2009, which you can get with the code you suggested. But what does "ACAD-7005:409" stand for?
Hallex
Message 2 of 5 (243 Views)
Re: Get short-cuts - open
08-19-2012 12:04 PM in reply to: Ertqwa
Try this one
Dim appver As Object = TryCast(My.Computer.Registry.GetValue("HKEY_CURRENT_USER\Software\Autodesk\AutoCAD", "CurVer", Nothing), Object)
        If appver IsNot Nothing Then
            MsgBox("you have " + "Autocad.Application." + appver.ToString() + " installed")
        Else
            MsgBox("Out of luck, sorry, use your old code instead")
        End If
~'J'~
Valued Contributor
Ertqwa
Message 3 of 5 (197 Views)
09-26-2012 11:27 AM in reply to: Hallex
Ty for your reply.
ADN Support Specialist
Balaji_Ram
Message 4 of 5 (180 Views)
09-28-2012 07:32 AM in reply to: Ertqwa
Please refer to this for the details on ProductID and LocaleID :
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=9120436&linkID=9240617
http://through-the-interface.typepad.com/through_the_interface/2006/09/automatic_loadi.html
Balaji
Developer Technical Services
Autodesk Developer Network
Valued Contributor
Ertqwa
Message 5 of 5 (169 Views)
09-28-2012 10:35 AM in reply to: Balaji_Ram
Great, ty!
