.NET
Get|Set Alignment of DBText
2 REPLIES 2
acedmond
517 Views, 2 Replies
I'm receiving a DBText object from the User. I want to create a given number of DBText objects changing the text string based on entered information. I want all of the newly created DBText objects to have the Same Justification. I know the DBText object Has (Boolean IsDefaultAlignment) and (Point3d AlignmentPoint), but there doesn't seem to be a way to get what the Alignment is of the Selected obj.
Any help is greatly appreciated,
Adam
2 REPLIES 2
in reply to: acedmond
Use something like this:
[CommandMethod("DBTEXT")]
public void dbtext()
Document doc = acadApp.DocumentManager.MdiActiveDocument;
Editor ed = doc.Editor;
Database db = doc.Database;
PromptEntityResult res = ed.GetEntity("\nSelect text: ");
if (res.Status != PromptStatus.OK) return;
using (Transaction tr =
db.TransactionManager.StartTransaction())
DBText text = tr.GetObject(res.ObjectId, OpenMode.ForRead,
false) as DBText;
ed.WriteMessage("\nAlignment is " +
text.HorizontalMode.ToString());
tr.Commit();
I wrote, the previous code to fast.... and forgot something - to check if we
select a text....:
//PromptEntityOptions prOpt = new PromptEntityOptions("\nSelect
text: ");
//prOpt.SetRejectMessage("\nText object only!");
//prOpt.AddAllowedClass(typeof(DBText), true);
//PromptEntityResult rs = ed.GetEntity(prOpt);
false) as DBText;
if (text != null)
tr.Commit();
”Boost
