.NET
Get position and bounding box of a BOM table
1 REPLY 1
458 Views, 1 Reply
I need to get the position and boundig box of the table "bill of materials". Any idea?
  Public Shared Sub GetPosicionBOM()
    Dim acadApp As AcadApplication = Nothing
    Dim symMgr As McadSymbolBBMgr = Nothing
    Dim symBOMs As McadBOMs = Nothing
    acadApp = DirectCast(Autodesk.AutoCAD.ApplicationServices.Application.AcadApplication, AcadApplication)
    symMgr = acadApp.GetInterfaceObject("SymBBAuto.McadSymbolBBMgr")
    symBOMs = symMgr.BOMMgr.GetAllBOMTables(True)
    If symBOMs IsNot Nothing AndAlso symBOMs.Count > 0 Then
      For Each symBOM As McadBOM In symBOMs
        ' I neet to get the position and bounding box of the object symBOM
      Next
    acadApp = Nothing
    symMgr = Nothing
    symBOMs = Nothing
  End Sub
thansk,
Ane
1 REPLY 1
Finally I found the solution;
  <CommandMethod("PartListBoundingBox")> _
  Public Sub PartListBoundingBox()
    Dim doc As Document = Application.DocumentManager.MdiActiveDocument
    Dim bt As BlockTable = Nothing
    Dim btr As BlockTableRecord = Nothing
    Dim objId As ObjectId = Nothing
    Dim partList As Entity = Nothing
    Using tr As Transaction = doc.TransactionManager.StartTransaction
      bt = DirectCast(tr.GetObject(doc.Database.BlockTableId, OpenMode.ForRead), BlockTable)
      btr = DirectCast(tr.GetObject(bt(BlockTableRecord.ModelSpace), OpenMode.ForRead), BlockTableRecord)
      If btr IsNot Nothing Then
        For Each objId In btr
          If objId.ObjectClass.DxfName.ToUpper = "ACMPARTLIST" Then
            partList = tr.GetObject(objId, OpenMode.ForRead)
            If partList.Bounds.HasValue Then
              MsgBox("MinPoint (" & partList.Bounds.Value.MinPoint(0).ToString & "," & partList.Bounds.Value.MinPoint(1) & ")" & Chr(13) & _
                          "MaxPoint (" & partList.Bounds.Value.MaxPoint(0).ToString & "," & partList.Bounds.Value.MaxPoint(1) & ")")
              Exit For
        Next
      tr.Commit()
    End Using
  End Sub
”Boost
