.NET
Get Point Collection from 3dsolid
7 REPLIES 7
Message 1 of 8
1354 Views, 7 Replies
I know this must be an easy answer, but for the life I me I can't find the method that returns a point collection for a given 3dsoild.  I have to think that a property exists that contains all the points for a solid (the ones shown when you select a 3dsolid).  I appreciate the help.  Thanks!
7 REPLIES 7
Message 2 of 8
Alexander.Rivilis
Solution: http://through-the-interface.typepad.com/through_the_interface/2008/09/traversing-a-3d.html
Facebook | Twitter | LinkedIn
Expert Elite Member
Message 3 of 8
Thank you for the link.  I guess it wasn't quite as easy as I would have thought.  I figured there would just be a property for 3dsolids that contained all the points.  Never the less, I can probably get that code to work.  Thanks again.
Message 4 of 8
_gile
If you only need the solid vertices, you don't need to run through the whole brep tree.
Here's a little sample.
        public Point3dCollection GetSolidVertices(ObjectId id)
            Database db = HostApplicationServices.WorkingDatabase;
            using (Transaction tr = db.TransactionManager.StartTransaction())
                Solid3d sol = tr.GetObject(id, OpenMode.ForRead) as Solid3d;
                if (sol == null) return null;
                try
                    Point3dCollection pts = new Point3dCollection();
                    using (Brep brp = new Brep(sol))
                        foreach (var vtx in brp.Vertices)
                            pts.Add(vtx.Point);
                        return pts;
                catch { return null; }
Gilles Chanteau
GileCAD
GitHub
Message 5 of 8
in reply to: _gile
Thanks _guile, that was more along the lines of what I was looking for.  Excellent.
Message 6 of 8
Hugh_Compton
Sorry for my ignorance but when I convert this to VB.Net I get an unknown type for 'var'...?
Message 7 of 8
_gile
in reply to: Hugh_Compton
In C#, var keyword stands for 'implicit type', the (strongly typed) variable type is determined by the compiler at edition time.
In this case, the infered type is: Autodesk.AutoCAD.BoundaryRepresentation.Vertex
Gilles Chanteau
GileCAD
GitHub
Message 8 of 8
Hugh_Compton
in reply to: _gile
Thanks Giles!
”Boost
